D::Luz
10 years 3 months ago - 10 years 3 weeks ago #12916 by sl1200mk2
D::Luz was created by sl1200mk2
I'm very please to announce D::Luz (pronounce Diluz), a fully integrated remote for iOS && Android (made by Pancho).
as for today, it's in mature coding stage but the app is not yet available on the AppStore as we need testers for iOS
it's neither available on the GooglePlay store...
so if you're interrested in testing the app:
- (for iOS users), please send your email to register you as tester. EDIT : available directely on the AppStore now ( itunes.apple.com/ch/app/d-luz/id1129756923?l=en&mt=8 )
- (for Android users), please download D::Luz here ( getdlight.com/index.php/downloadfr/category/35-remote ).
the remote is fully compatible with actual coding style (aka 4.0.0-b70)
we can talk with the dev in this topic.
please test and report!
may you consider making DONATION...
enjoy
Last edit: 10 years 3 weeks ago by aroom.
The following user(s) said Thank You: pancho
10 years 3 months ago #12917 by celio
Replied by celio on topic D::Luz
Bien intéresse pour faire des test sur iPhone et iPad.
A bientôt. Célio.
celio.noel@gmail.com
10 years 3 months ago #12918 by sl1200mk2
Replied by sl1200mk2 on topic D::Luz
@celio
t'as du recevoir une invite.
10 years 3 months ago #12926 by dubbertib
Replied by dubbertib on topic D::Luz
Bien interressé pour essayer également!
garnier.thibaut@gmail.com
A + dubbertib
10 years 3 months ago #12929 by sl1200mk2
@thibaut
t'as du recevoir une invit...
merci les gars de dire ce que vous pensez de D::Luz.
10 years 3 months ago #12932 by got
Replied by got on topic D::Luz
yop
j'essayerai aussi quand j'aurai un peu de temps sous android
10 years 3 months ago #12933 by fIfOU
Replied by fIfOU on topic D::Luz
Good news !
Je veux bien Beta tester la version iPhone/iPad..
(fifou[at]familux.com)
Philippe
10 years 3 months ago - 10 years 3 months ago #12934 by pancho
Replied by pancho on topic D::Luz
@fifou : ajouté
pancho, le dev de D::Luz, en attente de vos retours
petite note : si votre device est connecté à plusieurs réseaux (3G +wifi par ex)
vous devez choisir la D::Luz IP Adress (combobox bleue) étant dans le même sous réseau que la machine D::Light
puis "request" et normalement, connected s'allume et c'est parti...
petite note 2 : sur iPhone, la connexion par réseau ad-hoc (cad un réseau créé par l'ordi) ne fonctionne pas encore
il faut soit passer par un routeur, soit par un partage de connexion du tel.
Last edit: 10 years 3 months ago by pancho.
10 years 3 months ago #12935 by dubbertib
Alors je viens tester la teleco D::Luz sur un Phone 5s iOS 9.3.2!
mes retours et ressenti a chaud :
tout d’abord pas de plantage tout marche a merveille, installation easy par rapport a dlightpad avec touch osc!
pas de perte de contrôle quand le téléphone se verrouille/déverrouille contrairement a touch osc et la on est conten!
Home : les + : mortel de pouvoir recorder et updater, rappel des group et subs mortel aussi, charger un cue en x2 et goto marche bien aussi( mais je me demande ci cette dernière n’aurait pas sa place dans Scène???)
les - : touches un peu petite(taille du patch se serait mieux), slide sur master scène et master subs pas très clair au début il faut chercher un peu
Subs : les + : sobre fonctionnel marche nickel
les - : faut le trouver le slide dans la partie noire et vide, peut être un bouton serait le bienvenue car pas très clair non plus
Scene: les + : joystick mortel, step + et - marche très bien également
les - : visualisation du transfert ( serait bien de le voir),
Patch: les + : parfait
A +
10 years 3 months ago - 10 years 3 months ago #12936 by pancho
@ dubbertib : Merci pour tes retours, c vraiment essentiel !!!
Yes!!
et tu peux choisir vers quoi tu goto en double cliquant sur goto : cue/step/id
il faut faire des choix de place... si je met un clavier numérique sur la scene, pas de place pour les textes...
>> le souci c que c'est codé pour pleins d'écrans très différents, donc le résultat est très variable... et la moindre variation est lourde de conséquence...
et honnetement, un 5s, c pas le top, niveau taille d'écran... (m si c'est ce que j'utilise pour les tests...)
tu peux préciser?
oui, il faudrait pe que j'affiche le cadre du sub... c'était pour l'esthétique...
j'ai pas compris ce que tu veux dire...
c le role des sliders rouge et vert ou j'ai pas compris non pus?
Merci encore pour ces retours en tous cas!!
10 years 3 months ago #12937 by dubbertib
Yes!!
>>> yes je suis d'accord
et honnetement, un 5s, c pas le top... (m si c'est ce que j'utilise pour les tests...)
>>> yep je comprend bien la problematique
tu peux préciser?
>>> au debut on veut cliquer dessus comme un bouton( genre selection de la fonction puis on slide avec slide , moi j'ai fait comme ça la première fois)
>>>cela revient ' l'affichage du cadre du sub
>>> yes mais ils ne bougent pas ,du coup on ne sait pas ou en est le tranfert!
autre chose le bouton enter pour valider un record cue serait mieux vers rec et update non( c juste pour pinailler)
sinon c du top
bravo
10 years 3 months ago - 10 years 3 months ago #12938 by pancho
@ dubbertib
en lisant plusieurs de tes commentaires, je suis pas sûr que tu aies le retour d'info...
as-tu appuyé sur request dans l'onglet OSC, et validé dans Dlight ?
-du coup, une led verte doit s'allumer à côté de connected...
10 years 3 months ago #12939 by fIfOU
Merde, il faut iOS8.
Je suis battu.. !
10 years 3 months ago - 10 years 3 months ago #12940 by dubbertib
@ pancho
yes j'ai fait tout ça!
Last edit: 10 years 3 months ago by dubbertib.
10 years 3 months ago - 10 years 3 months ago #12941 by pancho
@duber
la led est verte?
tu es connecté comment? (routeur ou adhoc?)
dans dligth, setup, osc writer, l'ip et port de ton tel est bien référencée?
tu as bien 1 seul D::Luz de lancé? (si tu double clique sur home tu vois bien 1 seule instance?)
as tu certains retour d'info?
-la selection et les niveau des master scene et sub dans le home
-le n° et nom de page, les niveaux et contenus des subs
-les textes dans le scene
-les n° de ch et dimmer dans le patch
parce que normalement,
-les Master scene et sub et les subs se remplissent et bougent en f° de leur niveau
-X1 et X2 suivent le transfert
Time to create page: 0.678 seconds
