4.0.0_b51
10 years 11 months ago #11049 by boeckel
Replied by boeckel on topic 4.0.0_b51
Autre indication.
Jusqu'a présent à chaque connexion du pilote USB DMX, OSX me demande mon pwd.
Et là en b48-50, je n'ai même pas l'invite.
10 years 11 months ago #11050 by jeanmig
Replied by jeanmig on topic 4.0.0_b51
Bonsoir,
Comme je l'ai signalé dans le sujet "MAC ENTTEC MK2 et DLIGHT", j'ai le même problème avec Mon interface Enttec usb dmx pro mk2.
Cordialement,
Jeanmichel
10 years 11 months ago #11051 by Bestia Humana
Replied by Bestia Humana on topic 4.0.0_b51
Hi to everyone.
I try install the new beta and don't work in my computer.
b51 only works with Xquartz 2.7.8?
I have a Macbook pro 2011 OSX 10.10.5 Xquartz 2.7.7
Thank you for your support.
Hasta luego!!!!
edu
WHEN THE MUSIC IS OVER
TURN OFF THE LIGHTS
10 years 11 months ago #11052 by sl1200mk2
Replied by sl1200mk2 on topic 4.0.0_b51
@edu,
Ola
yes, it runs with Xquartz 2.7.8
10 years 11 months ago #11072 by reitrop
Replied by reitrop on topic 4.0.0_b51
Bonjour
MBP os 10.10.5 _ Version DL4.0.0_B51 _ Xquartz 2.7.8
Dans la fenêtre "setup" l'activation "usbDMX"
ne fonctionne pas
10 years 11 months ago #11077 by Bestia Humana
Hi to everyone.
I tried this morning load a palette on a submaster and Dlight crash.
Before this, I couldn't put on my ENTTEC MK2
I work on MacBook Pro 2011 10.10.5 Xquartz 2.7.8
edu
TURN OFF THE LIGHTS
10 years 11 months ago #11078 by sl1200mk2
Hi Edu,
Was it a global palette?
Can you try with a colour palette?
10 years 11 months ago #11081 by Bestia Humana
It was a global palette.
But I can't work with my enttec!!!
The setup no work!!
edu
TURN OFF THE LIGHTS
10 years 11 months ago #11086 by vbs
Replied by vbs on topic 4.0.0_b51
Hi,
I notice that i can not remove a group any more ???
In the display syntactic line the @mode disappear almost in the left corner
Is it posible to add wait time to a chaser
Regards Vincent
10 years 11 months ago #11087 by vbs
Hi,
If i try to import Ascii file it crash even if i export it first and try to import
Regards Vincent
10 years 11 months ago #11088 by fake
Replied by fake on topic 4.0.0_b51
about USBDMX PRO,
on El Capitan, a fresh install with nothing added, enttec is recognized...
so it works on MacOS 10.11
on MacOS 10.10, I've no way to try....
@edu,
does it also crash with a color palette?
@Vincent
good catch
in which window?
did you try to enlarge the window?
nope,
but you can use DelayIn + DelayOut in order to act like a waitTime.
10 years 11 months ago - 10 years 11 months ago #11090 by totoine
Replied by totoine on topic 4.0.0_b51
Alors nico, on utilise un fake pour poster ? ;)
Petite remarque à la con, en installant la b51 sous Windobe, il m'a crée un dossier 'DLight 3.0.20'... il doit y'avoir un chiffre pas mis à jour depuis longtempts dans l'installeur
Last edit: 10 years 11 months ago by totoine.
10 years 11 months ago #11111 by totoine
Allez hop, petit tour de trouvaille de mes derniers tests :
Chargement de palettes dans un sub : si aucune palette n'est crée mais que l'on va dans la section palette dans Load Stock de la fenêtre sub :
Code:
PRIMARY selection doesn't exist or form "STRING" not defined PRIMARY selection doesn't exist or form "STRING" not defined while executing "selection get" invoked from within ".mlnc.m2.m invoke active" ("uplevel" body line 1) invoked from within "uplevel #0 [list $w invoke active]" (procedure "tk::MenuInvoke" line 50) invoked from within "tk::MenuInvoke .mlnc.m2.m 1" (command bound to event)
Ca quitte pas, ca marche toujours, mais voilà juste un message d'erreur.
D'ailleurs, ca le fait sur toute liste vide.
Chargement de chase, suite au post de lavilladesoiseaux , ca ne marche pas.
Par contre, on peut le charger via les masterLink quand même...
J'avais un autre truc, mais je me souviens plus, ca va revenir...
Chargement de Sample, dans un fichier vide, il y a un sample fantome qui est dans la liste
10 years 11 months ago - 10 years 11 months ago #11122 by nomatter
Replied by nomatter on topic 4.0.0_b51
Hi,
Macbook pro 10.11.1 (el capitan), xquartz 2.7.8, _b51, Enttec DMX PRO USB.
It works.
But I cannot load chase in submasters? Any clue?
Than a hint: now that we can have devices in chases do you think to give chance to have scripts or functions or patterns to move them?
Thanks,
Carlo.
PS: ok, now I see another thread about this issue. It was in french and I missed to read it.
Last edit: 10 years 11 months ago by nomatter.
10 years 11 months ago #11124 by Jefff
Replied by Jefff on topic 4.0.0_b51
Xquartz 2.7.7 + Dlight b50 works fine.
Time to create page: 0.302 seconds
