ultraDMX MAX
3 years 3 months ago #25331 by sl1200mk2
ultraDMX MAX was created by sl1200mk2
dmxKing.com start releasing their new products and I was able to put my hand on the ultraDMX MAX.
Design is good and smart but they've decided to completely change their internal code which means D::Light cannot run it (as for DL 4.3.20).
I'll work on it ASAP and let you know.
The following user(s) said Thank You: zenerve
3 years 3 months ago #25350 by sl1200mk2
Replied by sl1200mk2 on topic ultraDMX MAX
I got it to work on macOS
3 years 3 months ago #25358 by sl1200mk2
I got it to work on Windows and Linux also :)
Input DMX is also working as long as eDMX Configuration is used to set the unit in 'USB DMX Forward'
3 years 1 month ago #25526 by sl1200mk2
3 years 1 week ago #25666 by sl1200mk2
dispo chez Soliled:
www.soliled.com/brand/dmxking/
2 years 11 months ago #25865 by zenerve
Replied by zenerve on topic ultraDMX MAX
Marche pô sur Linux );
Testé 4.3.21-debian et dernière version, 4.3.25-mint
Ok sur Mac (intel 10.15)
D'avance merci
Jean-Philippe
2 years 11 months ago #25866 by sl1200mk2
@zenerve,
Je m'en occupe en rentrant la semaine prochaine.
Ne faudraifaudrait-il pas écrire une nouvelle règle udev?
2 years 11 months ago #25868 by zenerve
Le message d'erreur est "Eh, dude, no ftdi here, going back to sleep lol"
...enfin quelque chose comme ça... quand on essaie d'allumer le dmx.
Udev identifiait le chip ftdi pour donner la permission de s'en servir, il me semble que ce n'est plus d'actualité (je n'ai plus dû manuellement ajouter une règle depuis lurette)
Je regarderai et mettrai un update ici si ça marche.
2 years 11 months ago #25884 by sl1200mk2
@zenerve,
poursuivons un peu cette idée de règle udev... t'as quoi comme règle écrite dans  /etc/udev/rules.d ?
et si jamais tu peux la modifier comme indiqué dans le wiki  getdlight.com/wiki/index.php/Interfaces_DMX#Linux
pour le ultraDMX MAX, ATTRS{idVendor}=="0x1FC9"
ATTRS{idProduct}=="0x0094"
2 years 11 months ago #25894 by zenerve
Dang, c'est moi qui ai rédigé cette partie du wiki.
Ô_Ô 2016 Ô_Ô
Sur Tumbleweed, il n'y a qu'un "placeholder", 70-persistent-net.rules, qui est vide.
Je me souviens d'un piège à l'envers, c'est que si tu installais QLC+ tu avais par défault la solution puisque QLC+ installait la règle. Ce ne semble plus être le cas, j'ai QLC aussi ici. M Calegari a dû, comme toi, réagir et il faut la dernière version -git pour que ça fonctionne.
L'interface est en tournée toute cette semaine, je ne peux pas tester.
Merci pour les ID Vendor etc ; j’essaie dès que je peux. Tu as créé une règle toi ? On est d'autant plus confus que mon collègue utilise Mint, comme toi j'imagine.
2 years 11 months ago #25895 by sl1200mk2
nope...
à part le raspberryPi j'ai pas de linux en natif ici...
mais je vais essayer sur le Pi et je te dirais.
2 years 11 months ago #25910 by sl1200mk2
je viens d'essayer sur le pi, sans tweak de la machine et ça fonctionne direct, sans avoir à écrire de règle...
le raspberryPiOS est basé sur la debian12
2 years 10 months ago #25956 by zenerve
Nop (version 4.3.26 Mint sur Tumbleweed)
J'ai crée la règle "comme si on était en 2016" et ça change rien, D//Light continue à se plaindre qu'il ne voit pas de FTDI
J'ai rajouté la ligne comme suit dans le format original de la wiki :
Code:
# Newer NXP chips (DMXKing "MAX" series) SUBSYSTEM=="usb*", ACTION=="add|change", ATTRS{idVendor}=="1FC9", ATTRS{idProduct}=="0094", MODE="0666"
Le terminal retourne :
Code:
unable to open ftdi device: -6 (ftdi_usb_reset failed)
quand j'essaie d'allumer le dmx.
Et oui, ça marche avec l'ancienne interface, UltraDMX Micro. Pour aller plus loin j'ai booté Linux Mint en version Live, j'ai installé D::Light, et essayé aussi - nop nop nop, toujours pas.
): Y'a un moment je vais appeler soliled pour voir s'ils remboursent, j'en ai acheté deux de bonne foi et en confiance :(
2 years 10 months ago #25957 by sl1200mk2
et peux-tu essayer de booter sur un Live de la Debian12?
2 years 10 months ago #25958 by zenerve
Ben j'ai fait plus mieux : j'ai installé debian 12.2.0 carrément, et emprunté un dimmer.
Marche pas.
Triple vérifié : l’interface "Max" marche sur Mac/Windows ; sur Debian D::Light fonctionne avec l'ancienne interface FTDI, et D::Light rapporte toujours
<<unable to open ftdi device: -6 (ftdi_usb_reset failed)>>
Si je branche l'autre :(
Time to create page: 0.253 seconds
