4.1.07 dev cycle
6 years 9 months ago #19406 by sl1200mk2
4.1.07 dev cycle was created by sl1200mk2
let's go !!
bon j'ai pas pu finir pour aujourd'hui mais voilà ce qui se profile... new UI for everyone
6 years 8 months ago #19411 by stebian
Replied by stebian on topic 4.1.07 dev cycle
Oh la la, looking good! You are going to divide into different windows which are then freely movable?
In 4.1.05 and 06 I noticed groups cannot be recorded. It says a Group was recorded/updated but it wasn't. The question pops up but the next window in which I'm asked to give a name for the group never appears.
Any thoughts on that?
stephan
6 years 8 months ago #19412 by sl1200mk2
Replied by sl1200mk2 on topic 4.1.07 dev cycle
Hi,
yeah, that's the plan :)
it's already like that in Native macOS version and the more I use it, the more I like it...
I also like the design of new Asus laptop with a semi-second screen on the keypad. And it's a good place for the submaster's window :)
how do you do to record groups? via shortcut? via OSC? via the group button on the main window?
6 years 8 months ago #19414 by leoclarys
Replied by leoclarys on topic 4.1.07 dev cycle
Du coup je reposte: Tu avais parlé à un moment de mettre un raccourci "all" pour la selection de certains paramètres dans le DC, genre pour les blades. Ça serait cool!
6 years 8 months ago #19415 by sl1200mk2
@leo,
thanks, will do
6 years 8 months ago #19416 by Benji21
Replied by Benji21 on topic 4.1.07 dev cycle
Juste pour signaler que j'avais le même message d'erreur dont Celio parle dans le Topic 4.1.06. Il avait posté le log (désolé je l'ai pas sur cet ordi).
Ca le fait quand je sélectionne un circuit de device sauf un, une source4-tungsten, donc sans paramètres de couleurs, je sais pas si c'est lié.
6 years 8 months ago #19417 by Poypoy
Replied by Poypoy on topic 4.1.07 dev cycle
Salut Nicolas,
Concernant la bascule d'affichage du Pavé numérique vers les Palettes, sachant qu'on ne glisse plus de l'un à l'autre, je me posais la question de la pertinence du déplacement du pavé contenant {Switch, - % +, Balance, Refresh), ainsi que du double clic sur ce bouton.
Cette partie pourrait rester à sa place, ce serait plus lisible, un pourquoi pas un clic unique pour la bascule?
6 years 8 months ago #19422 by stebian
Via OSC shortcut. But the normal shortcut didn't work either
stephan
6 years 8 months ago #19425 by zanpierre
Replied by zanpierre on topic 4.1.07 dev cycle
Hello
Petit rappel ici pour le bug d'incrément des FINE en limite à 0 ou 100 :)
z
6 years 8 months ago #19429 by sl1200mk2
so...
4.1.07_b1 is online
-new option in the SetUp for User Interface: attached/detached
@zanpaul
ça doit être corrigé
@benji21
@leo
done :)
merci pour vos tests,
6 years 8 months ago #19430 by sl1200mk2
@stebian,
I've forgotten to check on the win platform, sorry...
@poypoy
en interne ça slide toujours... c'est plus facile pour moi de laisser comme ça...
pour la bascule en simple clic, je suis pas contre.
et si je suis ta proposition, tu dis que ça serait plus lisible avec le switcher tout en haut (ou tout en bas), le switch passe du pad à SEULEMENT l'écran des palettes (sans que le switcher ne bouge de place)
c'est ça?
6 years 8 months ago #19432 by leoclarys
Hello!
Super l'option attaché ou pas! (perso pour l'instant je préfère la version "compacte").
Ça marche super le "all" pour les paramètres.
Tu n'as pas encore remis le feature de copy pour les paramètres dans le DC?
6 years 8 months ago #19433 by sl1200mk2
@leo
la version détaché c'est bien quand t'as un iPad à côté ou plusieurs écrans... (remarque j'ai pas testé avec plusieurs écran...).
et la version détaché t'as une ligne de plus de texte, 80 ch, le dynamicBottom est mieux
cool
nope... je voulais la sortir avant le WE...
6 years 8 months ago #19434 by dFVarela
Replied by dFVarela on topic 4.1.07 dev cycle
Not working in Win10 64B!
Will try later on another computer!
dFVarela
6 years 8 months ago #19435 by sl1200mk2
@Daniel,
Hi,
here it works fine on win10.
would you mind trying to uninstall previous version first? or at least be sure that the instal won't pick up an existing dlight's directory
Time to create page: 0.218 seconds
