- Thank you received: 3
4.0.0_b53
- jeanmig
10 years 10 months ago - 10 years 10 months ago #11295
by jeanmig
Replied by jeanmig on topic 4.0.0_b53
J'ai des shows dans lesquels les flashs ne fonctionnent pas correctement. Si j'enregistre sous, le problème disparaît.
Cordialement,
Jeanmichel
mbp 2013/osx 10.10.5/DL4b53
Cordialement,
Jeanmichel
Last edit: 10 years 10 months ago by jeanmig.
10 years 10 months ago #11296
Replied by sl1200mk2 on topic 4.0.0_b53
@tous,
est-ce que vous pouvez poster ici vos sho sur lesquels vous avez constaté que les flashs ne fonctionnent pas (avant donc de les avoir passé par la b53).
comme ça on pourra tous essayer avec différents OS.
thanx,
thanx,
- totoine
- Thank you received: 18
- jeanmig
10 years 10 months ago - 10 years 10 months ago #11299
by jeanmig
Bonsoir,
Voici un show extra simple dont des flashs des subs ne fonctionnent pas correctement.
Cordialement,
Jeanmichel
Cordialement,
Jeanmichel
- dFVarela
- Thank you received: 5
10 years 10 months ago #11300
by dFVarela
dFVarela
Replied by dFVarela on topic 4.0.0_b53
Hello:
After a few tests i'm very confused...
If i start DLight and open any of the posted shows everithing seems OK, but if i then go to:
file--open--open .sho or open recent the SubFlash gets quite strange!
It is an erractic beaviour some times it's the 1st sub flash that doesn't work other times it's the odd ones, some times it's the 3+4+5...
Tested in Windows Vista 32b, I will try to test whit Linux 32b tomorrow!
dFVarela
- dFVarela
10 years 10 months ago #11301
by dFVarela
dFVarela
The previous tests where made wihtout a USB connected!
Whit my ultraDMX Micro connected the red squares turn red randomly and DLigth crashes on open recent, it hangs whit the message:
EXITING...
Close_Drivers
After stoping DLight process i have to disconnect the USB and connect it again in order DL can connect to USB!
EXITING...
Close_Drivers
dFVarela
10 years 10 months ago #11306
Hi guys,
after trying both totoine and JeanMichel sho, I don't succeed to reproduce the bug...
my config, DLb53, macOS 10.9, no usbDMX
at least, I've click on every flash button of both sho, and they all worked out.
so,
we still need to find out how to reproduce it...
another thing,
I have 2 $$ working weeks left, so I'll be more involved in DL in early December.
so,
another thing,
- jeanmig
10 years 10 months ago #11309
by jeanmig
Effectivement, le problème n'apparait pas systématiquement. J'arrive à le reproduire mais pas régulièrement. Par contre, j'ai constaté que lorsque le flash sub ne fonctionne pas, la touche solo n'est pas sélectionnable.
Cordialement,
Jeanmichel
Cordialement,
Jeanmichel
10 years 10 months ago #11310
ok,
quelle méthode utilises-tu pour ouvrir les sho? (cf daniel's post) est-ce que tu constates le bug qu'elle que soit la méthode d'ouverture du sho?
tu cliques sur les boutons de Flash ou tu fais comment pour constater ce bug?
est-ce que tu constates le bug meme si le fait de cliquer sur les flashs est une de tes premières actions, ou ça n'arrive qu'après x mille commandes?
si ça arrive dès après l'ouverture du sho ça pourrait etre un probleme d'initialisation des subs...
thanx,
thanx,
- jeanmig
10 years 10 months ago #11311
by jeanmig
- J'ouvre les shows avec les 2 méthodes (show & recent.)
- Je clique sur le bouton flash, et il n'y a pas de changement d'état ni d'affichage.
- Le probleme apparait dés la 1ère action du flash, et il ne disparait pas tant que je reste sur le show.
- Apparement, c'est aléatoire. Je ne trouve pas de logique.
Cordialement,
Jeanmichel
Cordialement,
Jeanmichel
- jeanmig
- jeanmig
- Jefff
- Thank you received: 7
10 years 10 months ago #11319
by Jefff
Replied by Jefff on topic 4.0.0_b53
Pareil que Jeanmig avec cette conduite.
plusieurs ouvertures successives : des fois tout fonctionne, des fois non.
Mac OS 10.11.1 Quartz 2.7.8
Je note au passage que l'icône du .sho est celui d'un exec dans le finder.
Time to create page: 0.302 seconds
