DL4 request
11 years 4 months ago #10051 by sl1200mk2
Replied by sl1200mk2 on topic DL4 request
does this happen on Kusjeerop7 ?
if so, on wich sub?
and isn't it in solo mode?
11 years 4 months ago - 11 years 4 months ago #10052 by Wilf
Replied by Wilf on topic DL4 request
:blush: yes I think I forgot to put it out of solo... Pardonnez-moi!
[edit] I had two identical subs on different pages, one with solo and one without solo, and I revoked the wrong one [/edit]
Last edit: 11 years 4 months ago by Wilf.
11 years 4 months ago #10053 by sl1200mk2
ouf B)
11 years 3 months ago - 11 years 3 months ago #10214 by Wilf
Ok, something I forget all the time: It would be great to see which cue is LIVE.
Because sometimes I Freeze the cue to go to another cue somewhere sooner or later to edit it. And I have to remember exactly which cue number I was when i froze D::Light. So if somewhere on the screen there would be a field where the live (active) cue is shown this would take some risk out of blind editing :)
Last edit: 11 years 3 months ago by Wilf.
11 years 3 months ago #10215 by quico
Replied by quico on topic DL4 request
Is it posible to have a litle popup (some help-description) when you point each element of the D:Light window?
11 years 3 months ago #10216 by sl1200mk2
@Wilf
freezing is old fashion style... maybe you would prefer edit cues directly from the cue editor thus there's no need for freezing
@Quico
If I do so, it will pollute a lot the main window...
11 years 3 months ago #10217 by Wilf
Are you calling me old (fashioned)?! :P
Freeze is like 'blind' on Compulite, which I've used many years before D::Light so it was the logical step. I'll look into cue window next time.
11 years 3 months ago #10250 by nomatter
Replied by nomatter on topic DL4 request
As discussed in other topics,
it would be great to have palette in chase and submasters, both flash and time.
In this way we can control devices with midi and timed.
If I select multiple devices in main window they all will appear in control windows (colour, beam, focus).
I think could be useful to be able to select them even in control windows to avoid repeated switching of windows.
And, I'm not sure if it's already possible, ability to type values in devices control windows (after clicking in the box)... I just found out the mouse wheel function.
Bye,
Carlo.
11 years 3 months ago #10265 by Jefff
Replied by Jefff on topic DL4 request
Peut-être une baguette magique en trois mode : Un où l'on voit tout les circuits, un autre où l'on ne voit que les circuits patchés et un dernier où il n'y a que les circuits utilisés dans le cue actuel et le suivant. Bref rajouter le mode patché.
Qu'en pensez-vous ?
11 years 3 months ago #10301 by Jefff
La possibilité d'envoyer un message OSC personnalisés ?
11 years 2 months ago #10464 by nosmile
Replied by nosmile on topic DL4 request
Un autre requête : un export PDF plus complet.
Je m'explique. J'utilise toujours l'export PDF afin de sortir une version papier de la conduite complête "au cas ou", en cas de grosse catastrophe (genre, PC et clef usb volé à 8h de route de chez moi et 3h avant une représentation) afin de pouvoir tenter de me demerder avec la console sur place. Mais je me rend compte que si les master link sont bien exporté, ce n'est pas le cas des FX. Serait-il possible des les ajouter à l'export PDF?
10 years 10 months ago #11358 by birt
Replied by birt on topic DL4 request
i always use the rehearsal run to check all timings and intensities according to the theatre where we are performing.
when i adjust intensities i just save and overwrite the cue i currently have on stage. this works well and easy.
but if at the same time a "wait" is running for the next cue it stops counting as soon as i overwrite the cue i'm in.
would it be possible to change this so it just keeps counting? that way the timing of follow-up cues in doesn't get messed up during rehearsal.
10 years 10 months ago #11391 by Wilf
Be careful with waits and timelines when overwriting cues - you can accidentally write over the wrong cue. Why not use proportional patching?
10 years 10 months ago #11392 by birt
because this is the way that i know and how i'm used to work. but feel free to tell me how to use other options.
10 years 7 months ago #11954 by leoclarys
Replied by leoclarys on topic DL4 request
Salut Nico!
Je reprends un spectacle sur lequel je dois lancer un CUE manuellement via crossfade et le suivant devrait se lancer automatiquement via un WAIT de 20sec. Pour l'instant le crossfade n'active pas le WAIT du CUE suivant, du coup je lance un GO avec un wait de 20 sec sur la montée et la descente. Ça fonctionne mais serait-il possible que le WAIT s'enclenche si on passe le Cue précédent en crossfade manuel?
