Midi Map Tilt-PAN-Zoom moving head
- NachoL
il y a 2 ans 11 mois #25919
par NachoL
Midi Map Tilt-PAN-Zoom moving head a été créé par NachoL
Hola, I wonder if there is a way in DLight to midi map Tilt, Pan and zoom to controller wheels. Can you explain me how to do it?. Is it possible to map it for example to one wheel and works for the selected Head?
Thank You
Thank You
il y a 2 ans 11 mois #25920
Réponse de sl1200mk2 sur le sujet Midi Map Tilt-PAN-Zoom moving head
Hi,
yes, patch your wheel to Midi dbWheels.
dbWheels are bounded to columns if the dynamicBottom. Thus if you display FOCUS, first wheel will behave on Pan, second on Tilt. If you display Colours, first wheel will behave on Red, etc...
- NachoL
il y a 2 ans 11 mois #25921
par NachoL
Réponse de NachoL sur le sujet Midi Map Tilt-PAN-Zoom moving head
Ok, Thank you!
- NachoL
il y a 2 ans 11 mois #25922
par NachoL
Ok, it works.
Would it be possible to assign a wheel to a parameter without selecting it in the dynamic bottom. For example a wheel that is always zoom just when selecting the Head?
il y a 2 ans 10 mois #25923
Hi,
nope... you'll need to use either a Palette or a microPalette loaded into Sub for that purpose.
- NachoL
il y a 2 ans 10 mois #25925
par NachoL
Ok, thanx.
Temps de génération de la page : 0.143 secondes
