KORG NANOKONTROL 2?
il y a 5 ans 3 semaines #21999 par polillin
KORG NANOKONTROL 2? a été créé par polillin
Hello, I'm planning to buy a Korg Nanokontrol 2 so that I can use it to regulate submasters in Dlight via MIDI. I suppose I could change through more than 8 faders with the substick option and changing pages of submasters. Am I right? Is it difficult to configure in Windows 10? Thanks!
il y a 5 ans 3 semaines #22000 par aroom
Réponse de aroom sur le sujet KORG NANOKONTROL 2?
yes you can use sub stick to switch sub pages and keep the faders mapped.
you'll have to use the soft from Korg to change some button from CC to Note. it's rather easy yes. and then the mapping can be done inside D::Light.
Les utilisateur(s) suivant ont remercié: polillin
il y a 5 ans 1 semaine #22052 par polillin
Réponse de polillin sur le sujet KORG NANOKONTROL 2?
OK. I have one more trouble. I'd like to change pages and keep each submaster's value. But if I leave, for instance, Submaster 1 at 80% and pass to page 2, if I want to touch the slider 1, it starts Submaster 9 at 80%, not in zero. Anyone understands my problem and can tell me if there's a way to do it? Thanks!
il y a 5 ans 1 semaine #22054 par aroom
have you tried the "Bypass level's anchor mechanism " option?
il y a 5 ans 1 semaine #22055 par polillin
It works!!!! Thank you very much, sir!!!!
