Midi
il y a 10 ans 9 mois #11511 par laverda
Midi a été créé par laverda
Hi i have a problem which midi in my 3.0.24
When i assign a channel to a midi with cc. That channel does not work normally being run from a master or in an FX. The channel will go to a value and stay there until i manually set its value to 0.
Anyone else had this problem? Any solutions?
il y a 10 ans 9 mois #11512 par sl1200mk2
Réponse de sl1200mk2 sur le sujet Midi
hi
can you please try with the latest beta to see if the problem persist...
il y a 10 ans 9 mois #11522 par laverda
Réponse de laverda sur le sujet Midi
Hi!
I have tried to get this version to work but i can not open it properly. It only initiates but the program itself does not open. I have a quite old mbp and have not updated osx to more than 10.8.5.
Maybe i should clarify that it is not the midi that does not work, it is only the Masters and the FX that creates channels getting stuck. The seuense and the ques work fine.
However i just discovered that disabling the midi outputs solves the problem :-)
Thank you for your reply
il y a 10 ans 9 mois - il y a 10 ans 9 mois #11523 par aroom
Réponse de aroom sur le sujet Midi
hi
to use the last beta, you'll need to upgrade xQuatz as well
il y a 10 ans 9 mois #11526 par laverda
Hi!
Ok thank you!
i have this version XQuartz 2.7.8 - 2015.10.17. Then there is only a beta version pre-release. Is that the one i need to get?
Thomas
il y a 10 ans 9 mois #11527 par aroom
as far as a know you need :
xQuartz 2.7.7 for all the version 3.0.x and 4.0.x until the DL_4.0.0_b50
and
xQuartz 2.7.8 for all the new releases, beginning with the DL_4.0.0_b51
if you struggle when starting the software, you can try to launch it with the terminal with this command :
Code:
or you can try to re-install xQuartz and reboot the computer
Temps de génération de la page : 0.141 secondes
