iPad Wing with TouchOSC
il y a 12 ans 6 jours #8621 par nomatter
iPad Wing with TouchOSC a été créé par nomatter
Hallo Nico,
I'm Carlo and I'm beginning to use d::light.
Actually I have not really used it because I'm waiting for a proper usb interface, but I'm studying and finding it very handy and similar to console I like and know.
I prefer using keyboard and shortcuts and manual crossfade between cues.
For a better (and future) use I'm developing an interface for TouchOSC on iPad to make programming easier.
I will have Pad and buttons for any function and shortcut.
And Playback and submasters too.
Here some notes on my work:
- since of lack of some OSC command in DL, I created a patch in Quartz Composer to receive from TouchOSC and send to DL. It pass DL built-in OSC command and emulate keystrokes for shortcuts useful in programming shows;
- DL sends back messages to TouchOSC;
This work could be avoided if Shortcuts in DL are also for OSC and non only for keyboard. Or if I buy OSCulator.
And there is another issue I couldn't manage without QC: X1 and X2 faders go crazy when I try to use them. I couldn't understand how to set them to work properly. The inversion of value at the end of a crossfade is a little bit tricky and they start to flicker on the following passage. So, for now they are not interactive.
Also I miss in DL, or I don't know how to, a way to store in a Submaster the content of Output without to create a Numbered Group, opening a Submaster windows, load a Group in it, close the window and confirm it. It seems not so practical to do by keyboard or shortcut. (But could be done)
For digits I use /pad/# message. It works great in main window but it doesn't in other windows such as Group or Submaster.
I have to finish to work on it and then, if you want I can share with everyone.
Other things I miss is a way to translate in TouchOSC 0-255 values in %.
Or to have as return messages /seq/X1 and X2 the cue number and not the step.
And, also maybe, a parametric way to name submasters so I can use Multi-faders or Multi-push button.
I keep going on this personal Wing to DL and I will tell you how it works on stage.
Thanks for your work, I will not miss to donate.
Carlo.
il y a 12 ans 4 jours #8629 par sl1200mk2
Réponse de sl1200mk2 sur le sujet iPad Wing with TouchOSC
Hi Carlo,
nice work wich can be even more than usefull in a way:
it can be a remote for moving lights!
I doubt touchOSC is a good tool for that because you cannot code very much...
maybe something more than www.charlie-roberts.com/interface/ can be usefull... but I didn't take time yet to make it works...
I guess that with Interface, we can build colored diagram in order to choose colors, etc....
and more over it's portable.
we can work on that.
yes, I know there's something wrong... but I didn't take time to manage what....
you're right but I have no solution for now....
this is why touchOSC is not so practical as you cannot script it...
please, if you have time take a look at Interface and let's discuss about that.
Temps de génération de la page : 0.186 secondes
