touchOSC hacking 4 Android
il y a 14 ans 1 mois #4999 par sl1200mk2
touchOSC hacking 4 Android a été créé par sl1200mk2
www.circuitbentobox.com/note/how-to-cust...ouchosc-for-android/
if you try this, would you mind report your results....
il y a 14 ans 4 semaines #5019 par dFVarela
Réponse de dFVarela sur le sujet touchOSC hacking 4 Android
My Android just got back from repair, I'll tested as soon as posible, i've got to make a show out of my home place so i'll be using DLight whit a ultraDMX Micro and then report it back to you!
dFVarela
il y a 14 ans 4 semaines #5020 par dFVarela
It doesn't work :( !
For some reason the Android version of TouchOSC doesn’t support Labels, so if you add them in your layout and use this workaround to load it, your whole layout will just be black and unusable.
I'll have to continue using Control! When a new dlPad.js?
dFVarela
il y a 14 ans 3 semaines #5021 par sl1200mk2
Réponse de sl1200mk2 sur le sujet touchOSC hacking 4 Android
Daniel,
thxx for testing this... it's a shame it does not work...
did you see the one Colin wrote?
i use it and it's good. his dlPad.js reside on the dlight-tools github.
Les utilisateur(s) suivant ont remercié: colinc
il y a 14 ans 3 semaines #5028 par dFVarela
It's a TouchOSC problem....:(
The one under: dlight-pad / control / dlPad.js?
It is the one i'm using but is missing things like 'GoBack', and so on...... But it works, focused everything today with it!
dFVarela
il y a 14 ans 3 semaines - il y a 14 ans 3 semaines #5030 par colinc
Réponse de colinc sur le sujet touchOSC hacking 4 Android
dfvarela écrit: It's a TouchOSC problem....:(
My version does have GoBack - and Pause, Blackout, Live (scene) and Blind ( prepas), and a whole separate page with 10 submasters. But it's a fork from Nico's so he will have to pull it, or I will try to attach it here
La pièce jointe Control_dlPadfile_2012-09-14-2.zip est absente ou indisponible
il y a 14 ans 3 semaines #5031 par sl1200mk2
@Colin
any idea of how to merge from your fork ?
il y a 14 ans 3 semaines #5041 par colinc
@Nico
(see also the other dlPad thread, where I've posted the same)
I have sent you a 'Pull Request' from my GitHub fork. If you go to the 'Help' tab on the GitHub pages, there is a section on 'Pull Requests, and also how you respond to the request, review my fork, and then the commands to issue to merge my fork into your repository.
My fork for the Merge command is 'github.com/colinctoo/dlight-pad'
Regards
Temps de génération de la page : 0.169 secondes
