DL 4.5 releases notes (English/Français)
il y a 2 ans 1 mois - il y a 2 ans 1 mois #27139
DL 4.5 releases notes (English/Français) a été créé par sl1200mk2
The upcoming 4.5 release introduces Intensity Tracking for conventional and motorised sources....here's fews words about it.
Tracking is already in place in DLight for device parameters, which means that as long as you don't ask a device to move, it won't move across steps. DLinks are used for this purpose and are registered within steps only when a move is requested (whether it's a move or any other parameter update).
Historically, channel levels were recorded for each cue, and this behavior has been in place since the beginning of DLight. With the introduction of tracking capabilities, channel levels are only registered in a cue when requested, a process known as 'block tracking'. This means that when you want a specific level for a channel, you need to apply block tracking to it, which starts a new tracking sequence for that channel. As a result, the channel level won't change until the next 'block tracking' marker is set.
There are several new functions related to Tracking:
There are two important scenarios to understand when creating new cues:
The new 'Overwrite' mechanism is designed to automatically block tracking for the desired cue. New levels will be updated in all instances where the desired cue is present, marking the beginning of a new tracking sequence.
Additionally, a new '.R' (note the dot) shortcut has been added for the 'Overwrite' mechanism.
The overall idea of tracking is to enable faster programming and to simplify screen readability. All starting points of tracked levels are displayed with an underscore, while non-tracked zero levels are displayed with a dot.
The tracking mechanism can be enabled in the Setup panel.
La prochaine version 4.5 introduit le tracking d'intensité pour les sources conventionnelles et motorisées. Voici quelques mots à ce sujet :
Le tracking est déjà mis en place dans DLight pour les paramètres des appareils, ce qui signifie que tant que vous ne demandez pas à un appareil de se déplacer, il ne bougera pas. Les DLinks sont utilisés à cette fin et ne sont enregistrés au sein des pas de séquence que lorsqu'un déplacement est demandé (qu'il s'agisse d'un mouvement ou de la mise à jour de tout autre paramètre).
Historiquement, les niveaux des circuits étaient enregistrés pour chaque pas de séquence, et ce comportement est en place depuis le début de DLight. Avec l'introduction des capacités de tracking, les niveaux des circuits ne sont enregistrés dans un pas de séquence que lorsqu'ils sont demandés par un processus appelé 'block tracking'. Cela signifie que lorsque vous souhaitez un niveau spécifique pour un circuit, vous devez appliquer le block tracking, ce qui démarre une nouvelle séquence de tracking pour ce circuit. En conséquence, le niveau du circuit ne changera pas jusqu'à ce que le prochain marqueur de block tracking soit défini.
Il existe plusieurs nouvelles fonctions liées au tracking :
Le système de tracking est conçu pour être à la fois ascendant et descendant (lors de l'utilisation de la fonction Update). Cela signifie que si vous mettez à jour le niveau d'un circuit à un pas de séquence où le marqueur de tracking n'est pas défini, DLight recherchera le précédent marqueur de tracking pour ce circuit et mettra à jour la cue chargée à ce pas de séquence. Le niveau mis à jour restera jusqu'à ce que le prochain marqueur de tracking soit rencontré.
Il y a deux scénarios importants à comprendre lors de la création de nouvelles cues :
De plus, un nouveau raccourci '.R' (notez le point) a été ajouté pour le mécanisme 'Overwrite'.
L'idée générale du tracking est de permettre une programmation plus rapide et de simplifier la lisibilité à l'écran. Tous les points de départ des niveaux trackés sont affichés avec un soulignement, tandis que les niveaux zéro non trackés sont affichés avec un point.
Le mécanisme de tracking peut être activé dans le panneau de configuration.
- The new 'Trk' button in the channel's sidebar, which is designed to set or release a tracking mark.
- The new 'toggle_trackingMark' shortcut, which toggles the tracking mark (sets a mark when there is none, and releases it when a mark is present).
- upd button (Update) for updating
- rec button (Record) for recording
- ovw button (Overwrite) for re-recording
- Recording a new cue at the end of the sequence is straightforward. The record panel allows you to choose whether or not to block tracking for this cue.
- Recording a cue that will be inserted between two existing cues gives you the option to block tracking for the cue that follows the new one. This mechanism ensures that the new cue won't automatically start a new tracking sequence for the channels.
- Le nouveau bouton 'Trk' dans la barre latérale des circuits, conçu pour définir ou libérer un marqueur de tracking (set/release).
- Le nouveau raccourci 'toggle_trackingMark', qui bascule le marqueur de tracking (définit un marqueur lorsqu'il n'y en a pas et le libère lorsqu'un marqueur est présent).
- upd bouton (Update) pour updater
- rec bouton (Record) pour enregistrer
- ovw bouton (Overwrite) pour re-enregistrer
- L'enregistrement d'une nouvelle cue à la fin de la séquence est simple. Le panneau d'enregistrement vous permet de choisir si vous souhaitez ou non bloquer le tracking pour celle-ci.
- L'enregistrement d'une cue qui sera insérée entre deux cues existantes vous donne la possibilité de bloquer le tracking pour la cue qui suit la nouvelle. Ce mécanisme garantit que la nouvelle cue ne commencera pas automatiquement une nouvelle séquence de tracking pour les circuits.
Temps de génération de la page : 0.141 secondes
