Virtualisation in Windows11
il y a 3 ans 8 mois - il y a 4 mois 3 semaines #24480
Virtualisation in Windows11 a été créé par sl1200mk2
Windows 11 have a new policy regarding security... without entering in details it means that Microsoft ships its new system as a 'Virtual System' (more or less exact but many users can understand).
:Light does not run on virtual system (as for 2023/02)...
So if
:light report your computer is running on a virtual system you need to disable it.
In order to do so there's several methods:
-First, you can try to disable Hyper-V mechanism as explained in attached document.
right after, you can try to activate/deactivate your licence.
If things goes well, you're good otherwise you'll need to tweak more...
-Second, you'll need to disable VBS (on Intel computer).
Thanks to @achille.dub here's a link that explain how to do so:
www.netcost-security.fr/guides/guides-te...er-les-performances/
it's in French but easily translatable (or find a source about the same topic in your language)
Hope this helps...
ps: Microsoft provides instructions to enable virtualisation:
support.microsoft.com/en-us/windows/enab...4b-a449-8ced115f58e1
You can follow them as well BUT you'll want to disable virtualisation
here's a link for Asus :
www.asus.com/fr/support/faq/1043992/
:Light does not run on virtual system (as for 2023/02)...So if
:light report your computer is running on a virtual system you need to disable it.In order to do so there's several methods:
Hope this helps...
Les utilisateur(s) suivant ont remercié: Spoonspoiler
il y a 3 ans 4 mois #25183
Réponse de sl1200mk2 sur le sujet Virtualisation in Windows11
une autre explication en Français:
- jbfer0201
il y a 9 mois 2 jours #29691
par jbfer0201
jbf
Réponse de jbfer0201 sur le sujet Virtualisation in Windows11
Bonjour Nicolas,
J'ai un acer windows 11 processeur amd ryzen 7 260 w/ radeon 780 m Graphics.
Après avoir exploré les différentes manipulations, mis à jour le bios avec le vendeur, je suis face à un problème la virtualisation ne peut pas être enlevée dans le bios ( pas affichée dans les actions possibles).
J'ai décoché tous les fonctions hyper v etc, la virtualisation est toujours en route....
Auriez-vous une idée?
Merci par avance.
jb
Merci par avance.
jb
jbf
il y a 9 mois 2 jours #29692
aucune malheureusement... si tu as acheté une licence je peux te la rembourser...
(écris moi en perso si c'est le cas)
mais pour l'instant je n'ai vu qu'un seul ordi comme ça.... qui est listé ici:
getdlight.com/forum/hardware-all/8272-co...not-work-with-dlight
as-tu essayé la méthode isolation du noyau / intégrité de la mémoire comme indiqué ici:
- jbfer0201
il y a 9 mois 2 jours #29693
par jbfer0201
jbf
Ce message contient des informations sécurisées
jbf
- Otchakbb81
il y a 3 mois 3 semaines #30466
par Otchakbb81
Réponse de Otchakbb81 sur le sujet Virtualisation in Windows11 Ordi DELL Plus 16620
Bonjour
Je possède un PC DELL Plus 16620 et j'ai déjà essayé beaucoup de choses. Faut-il déjà activer ou désactiver la virtualisation, je suis un peu perdu. Merci
il y a 3 mois 3 semaines - il y a 3 mois 3 semaines #30467
Temps de génération de la page : 0.210 secondes
