Enttec DMX USB PRO + OSX 10.11 El Capitan
il y a 11 ans 1 mois #10590 par nomatter
Enttec DMX USB PRO + OSX 10.11 El Capitan a été créé par nomatter
Hallo Nico and Mac users,
do NOT update OS X to the next version, El Capitan.
The interface Enttec DMX USB PRO (and D::Light) will not work.
Enttec is aware of the problem.
This is the answer of Enttec support to my question:
"Apple doesn't allow disabling the in-built driver anymore, which means you cannot use the D2XX driver that most DMX USB Apps rely on
For now, we will advise not to update, till we have more information on a workaround or a solution
There might be other Apps that support the Apple driver - which will allow DMX USB PRO to work on OS X 10.11"
We'll stay tuned,
bye,
Carlo.
il y a 11 ans 1 mois #10591 par sl1200mk2
Réponse de sl1200mk2 sur le sujet Enttec DMX USB PRO + OSX 10.11 El Capitan
Hi Carlo,
that's interesting...
DL do not use at all D2XX drivers...
but DL attempt to unload from the kernel some AppleFTDIDrivers...
which version of DL did you try?
do you have a preview of El capitan? or is it out?
il y a 11 ans 1 mois #10592 par sl1200mk2
can you read this thread:
forums.developer.apple.com/thread/12581
and try these commands from the terminal:
sudo chmod -R 755 /System/Library/ProlificUsbSerial.kext/
sudo kextload /System/Library/ProlificUsbSerial.kext/
and retry to see if USB properly work with DL
thanx,
il y a 11 ans 1 mois #10599 par nomatter
Réponse de nomatter sur le sujet Enttec DMX USB PRO + OSX 10.11 El Capitan
Hallo Nico,
thanks for the link.
I have a clean installation of last Public Beta of El Capitan. Definitive version will be released this or next week (we'll know on 9th)
I tried with b46 and yesterday I had an attempt also with b47.
For what I understand problem is SIP, System Integrity Protection. Apple doesn't allow Apps to modify system files. Period.
Kernel Extension could be added or edited only by certified or signed developer.
(Apparent) solution is to disable SIP by access to recovery mode (cmd + R) at boot and via Terminal "/usr/bin/csrutil disable"
Then reboot and d::light (and also Enttec Pro-manager) finds the interface.
For a few times.
Yes because, I don't know why, after a while it stop finding it. I've tried a lot, unsuccessfully.
I had to go to Recovery Mode, "clear" SIP, reboot, new recovery mode, disabling it again and the story starts again.
Odd, no?
That's my report.
Ah: ProlificUsbSerial.kext doesn't exist in my system. Even after disabling SIP.
Thanks a lot,
Carlo.
il y a 11 ans 1 mois #10602 par sl1200mk2
das ist fucked up...
il y a 11 ans 1 semaine #10787 par Morpho
Réponse de Morpho sur le sujet Enttec DMX USB PRO + OSX 10.11 El Capitan
Hi Guys,
Did anyone tried the Enttec ethernet DMX bot with 10.11 and Dlight ?
Is the the update possible ?
If not, will it be compatible soon ?
Thanks,
Florian
il y a 11 ans 1 semaine #10788 par sl1200mk2
I have a b48 running on MacOS10.11 with a valid usb connection to a dmxKing device
I need to polish it though...
il y a 11 ans 1 semaine #10790 par Jefff
Réponse de Jefff sur le sujet Enttec DMX USB PRO + OSX 10.11 El Capitan
Je confirme que la dmxusbpro enttec ne fonctionne pas avec elcapitan et b47
Du coup la b48 a l'air bien... :blush:
il y a 11 ans 1 semaine #10800 par nomatter
Hi Jefff,
you can try disabling SIP, the new System Integrity Protection.
Here, in Function section, you can find instructions to do it: en.m.wikipedia.org/wiki/System_Integrity_Protection
Let us know if it works for you.
Carlo.
il y a 11 ans 1 semaine #10802 par balgrim
Réponse de balgrim sur le sujet Enttec DMX USB PRO + OSX 10.11 El Capitan
Je confirme : avec la release de El Capitan et le SIP désactivé, l'enttec USB Pro n'est pas activée via dlight 4b47 !!
il y a 11 ans 1 semaine #10803 par sl1200mk2
in the Download/beta section I've pushed a DL_4.0.0_b48_X10_X11
be aware that it's not a finished beta (because DLink and TLinks for chases are not finished.... but you can have a look into it ;-) )
it's just to see how things are going:
opening existing sho
setup usb/dmx connection
etc...
thanx for your feedbacks
il y a 11 ans 1 semaine #10809 par balgrim
DL_4.0.0_b48_X10_X11 now working with Enttec USB Pro !
(Sytem Integrity Protection off)
Soon, will test over SIP on !
il y a 11 ans 4 jours #10839 par balgrim
Not working anymore.
I tested QLC+ working with the the Enttec USB dmx Pro.
il y a 11 ans 3 jours #10841 par sl1200mk2
I've made another attempt with b49...
available soon.
il y a 11 ans 3 jours #10842 par Jefff
ça fonctionne chez moi, El-capitan et Dlight pre-b38, l'enttec pro clignote bien.
Temps de génération de la page : 0.233 secondes
