Re: Mac osx 10.7.2, usb DMX Pro, not working!!
il y a 14 ans 8 mois #3917 par blixlab
there bis no DL file there. sometimes i have to trigger the qlab cue 3 times to get it to trigger DL but it still makes the go button red for 7 seconds before triggering the cue.
il y a 14 ans 8 mois #3918 par blixlab
Réponse de blixlab sur le sujet Re: Mac osx 10.7.2, usb DMX Pro, not working!!
also if its any help when it triggers the 0's in DL flicker for the 7 seconds.
il y a 14 ans 8 mois #3919 par sl1200mk2
Réponse de sl1200mk2 sur le sujet Re: Mac osx 10.7.2, usb DMX Pro, not working!!
did you try to set Device ID to 1 (just in case 0 is a broadcast address)?
il y a 14 ans 8 mois #3920 par blixlab
Ha that's It!!!!!! Sorry i should have thought to try that myself!!
il y a 14 ans 8 mois #3921 par sl1200mk2
what i do not know is if you found a bug with 0 deviceId or not...
i'll investigate that next week...
can you make another try is to set your dmx output to libusb, and tell me if everything is fine (of course with the last DLight app i sent you and ftdi drivers loaded)
il y a 14 ans 8 mois #3922 par blixlab
Ok just relaoaded drivers from installer as i had manually deleted them before.
All is working perfect! I seem to remeber Lanbox having an issue with id 0 also.
il y a 14 ans 8 mois #3923 par sl1200mk2
cool!
about lanbox, i think you can use it via artnet....
anyway, thank you for all these tests and please be aware to test 3.0.7_b11 when it'll be online (begin of next week)
il y a 14 ans 8 mois #3944 par sl1200mk2
please test 3.0.7_b11 !
il y a 14 ans 8 mois #3948 par blixlab
OK have it running nw and all seems good!
il y a 14 ans 8 mois #3949 par sl1200mk2
thanx,
as you maybe noticed, i removed midi show control ID 0...
have fun and think about donations if u use DL.
il y a 14 ans 8 mois #3950 par blixlab
Thanks,
I think the device Id issue is that qlab is "0" by default. All working good now, many thanks and ill let you know how i get on...
Temps de génération de la page : 0.159 secondes
