Mac osx 10.7.2, usb DMX Pro, not working!!
- blixlab
:light and i can not get it to work... the latest beta just shows blank windows and the last stable will not allow me to access the menus or recognize the USB DMX Pro.Can someone help and please give a basic up to date installation process for 10.7 and USB DMX Pro?
Any help would be greatly appreciated.
Ro
i've made mistake with the latest beta, i think i'll put an update today.
please be patient and try again when it'll be available.
- blixlab
Pleas which driver must i install?
Thanks
you can try to select /dev/usb-serial as modus operandi but in that case, you need to install ftdi driver that you can find here:
www.ftdichip.com/Drivers/VCP.htm
also once you've installed ftdi driver can you please give a try with libusb again just to be sure that it doesn't work in any case on your computer...
i mean, maybe drivers must be installed...
opendmx.net/index.php/OLA
- blixlab
:light! If you have any ideas as i am a little desperate at this stage... Connexion pour participer à la conversation.
can you try some command in a terminal (/Applications/utility/terminal) as described here
staton.us/electronics/python/OSX_FTDI_USB.html
here's the result from my terminal
brouhaha:daylight nico$ sudo kextstat | grep FTDI
145 0 0xffffff7f808b5000 0x8000 0x8000 com.FTDI.driver.FTDIUSBSerialDriver (2.2.16) <99 30 5 4 3 1>
can you post yours?
it's a shame because as i told you with a 'virgin' mac, i succeded to establish connection...
- blixlab
127 0 0xffffff7f8079b000 0x8000 0x8000 com.FTDI.driver.FTDIUSBSerialDriver (2.2.16) <104 31 5 4 3 1>
- blixlab
the command is
sudo kextunload /System/Library/Extensions/FTDIUSBSerialDriver.kext
- blixlab
- blixlab
here's what you gonna try:
be sure to have unload ftdi driver.
the attached zip is only the executable (modified of course, it will assume there's no ftdi driver)
Ctrl+Click on DLight icon, select show package contents (i don't exactly know in english), move to contents/Resources and put dezipped joined files in it
launch DL, create a new show and try to connect to usbPro via libusb.
my goal is to test if the applescript to unload ftdi drivers is faulty. as this executable assume there's no need to unload drivers
