Entec ODE
- plem
In Dlight 3.16 all is well, but only after I made an extra click on unicast/broadcast to change it once to broadcast.
In Dlight 3.20 this button is not there anymore and the entec doesn't work. It is perfectly recognized. The server starts without problems. But nothing happens.
In fi. MAX.MSP all functions well.
I (how stupid could I be) am on Mavericks on a Macbook Pro.
Any hints?
Thanks
Peter
- plem
The Entec ODE is on 10.0.1.81.
And as said, all is well in 3.16 after the extra clicks.
Thanks for the fast reply,
Best
Peter
- plem
On 3.20 there is no unicast/broadcast box. Could that be the problem? I think I remember that the entec ODE only functions in broadcast mode. Is 3.20 also in broadcast mode?
Even in the NMU app (the Entec-app for controlling the ODE) it is sometimes necessary to switch the output on, off again and on again before the device actually works. (This with the test option from within the app.) With the MAX external everything is without problems.
So maybe other ODE users can tell there experience, or you can think of something?
Thanks and all the best
Peter
- nosmile
(Do you use a router or connect it directly on your laptop?)
(I'm still on Montain lion thought, maybe it's a Maverick-only issue…)
- plem
(Unfortunately it is merely impossible to downgrade from Mavericks. I just was to soon this time. Tricked into it...)
Peter
first test with enttec ODE and Mac OS 10.9 (Maverick, wich I install because I'm obliged otherwise I would keep the 10.8 OS...)
ODE = 10.0.0.23
MAC = 10.0.0.77
subNet Mask for both 255.0.0.0
everything is fine here....
I've launched the broadcast ArtPoll to find the node, once recognized, I've set it to available, then I've launched the server and test with a PAR Led.
connection is direct.
no doubt you did the same....
except the IP, I do not remember if I've done something particular with the ODE.
so I don't think it's a problem with
:Light as the used computer has nothing special.++
- plem
I agree with the conclusion that it has to be something specific at my side then (hardware, software, firmware...?).
But I have to get the thing running on 3.20. But at least I know a lot more now about where to look.
Everybody thanks
Peter
- plem
But other software for fi. iPad doesn't find the ODE. So it is not really good. But it works in
:light. Fine!If it works with this cable then changing to another probably doesn't help, would it?
Thanks for the help.
Peter
happy new year!!
wich ethernet address did you changed?
if u use cable, you should only operate on the ethernet wired address (and switch off the wifi).
I don't understand the thing with the ipad... DL is not designed to run on ipad...
wich other software did you tried?
at least I'm glad it worked with DL.
- plem
What i did mean about the ipad is that I tried to get a connection from some specifis ipad programs that send artnet though wifi. Besides that I use the ipad with TouchOsc to control d::light. Great that you did build in the OSC options!
Best
Peter
