Astera Titan Tube in 4 pixel mode
il y a 3 ans 3 mois #25344 par SaFaRi187
Astera Titan Tube in 4 pixel mode a été créé par SaFaRi187
Hello!
Yet again another question.
I am working with several Astera Titan Tubes for an upcoming show.
The are in Mode 23 (Dim RGBAW 4 pixels).
So the full bar is divided in 4 pieces (each with their intensity and RGBAW).
See also attached personality file.
The problem is as follows. When I change the intensity in a cue, only the parameter dimmer is affected, not dimmer_2/4, dimmer_3/4, dimmer_4/4.
So only the level of the first segment of the bar is controlled by the level in a cue, not the full bar (the other 3 segments).
Any solution to this?
Or do I miss something?
Thanks in andvance!
B.
il y a 3 ans 3 mois #25345 par SafeTilt
Réponse de SafeTilt sur le sujet Astera Titan Tube in 4 pixel mode
you need to create a device for each RGBAW Dimmer group. Split your tube as needed.
Les utilisateur(s) suivant ont remercié: SaFaRi187
il y a 3 ans 3 mois #25346 par SaFaRi187
Réponse de SaFaRi187 sur le sujet Astera Titan Tube in 4 pixel mode
That's indeed the solution for me.
Stupid that I didn't think of it myself...
Thanks for helping me out!
Temps de génération de la page : 0.124 secondes
