4.1.09
:Light 4.1.09 is online.available for every supported 64bits systems. (Mac, Pc, Linux, raspberryPi4)
Enjoy,
- SoundSurfer
- Remerciements reçus 3
- SoundSurfer
- SoundSurfer
- SoundSurfer
so I've updated the front page of the web site, you were right it's better
I've tested patroonJannes and in no way I succeed to reproduce your issue. going back and forth from attached/splitted/attached/detached/splitted, everything is good here. macOS 10.15.3 also
so there must be something but I don't know what...
++ and take care
- SoundSurfer
perhaps it has something tot do that the original .sho file was created with an older version of dlight, but im not sure. Also, I am running "bettersnaptool" on my macbook, which enables me to easily give certain windows a fixed place on my screen..
keep safe! (physically and financially!)
- anatol
when i switched to the licensed version (4.1.06) it broke a few things:
- gtk libs gave a few errors (no big deal, just version conflicts and easily solved with a few symlinks and costum libs)
- the enttech box went wild and sent out random dmx values (i had to switch back to the beta version since did not find any apparent cause/solution)
1. did anyone have similar problems?
2. (follow up) has the problem been addressed in the most recent version?
4.1.09 is released also for Linux, did you try it? I think this version is really better than the 4.1.06.
this is weird as DL does not use gtk... it does use glibc but that's it.- gtk libs gave a few errors (no big deal, just version conflicts and easily solved with a few symlinks and costum libs)
which lib gave you trouble?
using 4.1.09, you'll need a licence in order to have a clean DMX.- the enttech box went wild and sent out random dmx values (i had to switch back to the beta version since did not find any apparent cause/solution)
when you launch DL, it should tell you (in the upper right part of the software) if it's running in DEMO mode (DMX is shitty) or if it is licensed.
- anatol
with the 4.1.09 i can't seem to get out of demo mode.
it might have to do with this error message:
../DLight-64-Linux/bin/libuuid.so.1: no version information available (required by /usr/lib/libfontconfig.so.1)
maybe if you'd package the linux version in something like appimage or snapcraft (not my first choice) it would save a lot of trouble.
when i tried to get the b72 to run on debian 64 i got nowhere because of lib version conflicts.
Hi,
how do you try to run DL? using the script.sh I provide?
because this script should link the exe against lib I distribute. this way, there should not have any lib conflicts (except the glib one of your computer).
- anatol
yep, i run it via the shell script (after the chmod +x DLight.sh thing)
i've got the several versions in different folders in my home mount
so far only the b72 version runs and behaves like it should except the non graceful exit: it hangs on the "close struct".
so just to be clear on this topic.
you run 4.1.09, but DMX is crappy? _ right? you need a licence.
you run 4.1.09 and your system complain about bad libuuid? _ right ? if so, I'll recompile libuuid for DL 4.1.10_b3
- anatol
(5.4.26-rt17-MANJARO #1 SMP PREEMPT_RT Sat Mar 21 18:11:27 UTC 2020 x86_64 GNU/Linux)
