4.0.0_b56
- Wilf
- Remerciements reçus 3
- Jefff
- Remerciements reçus 7
- Wilf
- leoclarys
- Wilf
it's a scrolling stuff that is adding extra space for sub and will hold new commands for the sub...
- bgoubert
- Remerciements reçus 22
crash en enregistrant une mémoire.
réouvert, les textes des subs ont changé de place.
bruno
ps: je ne reçois plus aucun mail des sujets auxquels j'ai souscrit, depuis 2 ou 3 mois. ???????
il va etre difficile celui là...
tu peux joindre le sho, stp?
vient sur l'IRC, faut demander à totoineps: je ne reçois plus aucun mail des sujets auxquels j'ai souscrit, depuis 2 ou 3 mois. ???????
- bgoubert
- vbs
I have a problem with my Ficture file.
When i make a new show i build a fixture with 19 channels.
I make a few presets and colors and stuff.
After i save the show and re open the show again my fixture file have no more channels.
After i import and patch the fixture again it works again but don,t understand.
The problem seems to be in the fixture file but don't know how
I enclose my Show and the fixture file.
- vbs
That seems to work thanks!
One other thing is how do i edit a pallet?
I select the device commands - palette select pallet nr7. make the adjustments in the device command and select update.
The it say first choose a pallet ????
See Pict 1
Also how do i get the device commands into the main software bord?
Pict 2
Regards Vincent
you have 2 methods to update a palette:
1) use the palette editor
2) once you have set new values for your device, type the palette number and click update
you can't...Also how do i get the device commands into the main software bord?
all the stuff that belongs to devices is handle in the 'Device Commands' panel.
- vbs
I will try that the update part.
About the control panel.
In the wiki at Device it say you can select in the control panel.
Or is this al ready not up to date any more.
Pic. Pallets
