pre 4.0.0_b48
il y a 11 ans 3 semaines #10672
pre 4.0.0_b48 a été créé par sl1200mk2
just for the record and as I'm very pleased...
I've succeded with TLinks in Chase :ohmy:
yep!! it opens windows
il y a 11 ans 3 semaines - il y a 11 ans 3 semaines #10673
Réponse de sl1200mk2 sur le sujet pre 4.0.0_b48
because it's a start for DLinks in Chase...
with adjustable times for parameters...
- Wilf
- Remerciements reçus 3
il y a 10 ans 11 mois #10899
par Wilf
Réponse de Wilf sur le sujet pre 4.0.0_b48
I tried this version and experienced two problems.
I use Qlab to send MSC and MIDI to trigger Dlight. After running Dlight an hour or so one time in stead of getting the triggered cue (MSC) I got a blackout. When triggering again the cue opened. A half hour later there is a moment where I trigger a cue AND flash a sub. This time Qlab froze. I could not change anything. No subs, no grand master, nothing. Even disconnecting and connecting the Enttec in the Setup did not work. I had to close Dlight and open it again.
il y a 10 ans 11 mois #10902
@Wilf,
Hi
is it reproductible?
did you triggered a cue that does not exists?
are you 100% sure that you trigger cue and not steps?
Hi
- Wilf
il y a 10 ans 10 mois #11237
par Wilf
Sorry I am responding so late, had a lot of tours and couldn't work with the new MacBook Pro in that time. It froze where previous versions didn't. It hadn't to do with non-occurring cues. I was just playing the show as usual. In the show I fire
:Light via Qlab; via MSC I go to different cues and with CC I open or close subs, sometimes rapidly and at the same time. The big freeze came when I fired a cue and a sub at the same time.
:Light via Qlab; via MSC I go to different cues and with CC I open or close subs, sometimes rapidly and at the same time. The big freeze came when I fired a cue and a sub at the same time. Connexion pour participer à la conversation.
- Wilf
il y a 10 ans 10 mois #11249
par Wilf
I just replicated the problem. Running the same system (Quartz 2.7.7 on 10.10.5 on a new retina MBP with b48).
:light gets stuck in a big way in a scene where I have a cue with FX's and I use MIDI to flash, to go to a cue and to open a sub. A lot of MIDI communication happening, not necessarily at the same time (the scene opens with a GO TO CUE 24, then after a minute or so it goes to cue 25 which has a long time in / time out, then after a minute or so later it ends with a GO TO cue 29.
In the Qlab of that scene I send simultaneously two midi note on (ch 1 note 1 vel 127 + ch 1 note 2 vel 127) and 20 milliseconds later a simultaneous note on of velocity 0 to both channels. These are lightning flashes and some flashes are at lower than vel 127. They are linked to the flash button though (so I flash at lower than full).
At the same time I have a smoke machine I operate. This is connected directly via another MIDI port (not via the internal bus I use for Qlab), namely the MIDI port of an icon icontrols. This one sends a CC on channel 1, cc # 55 to sub 15.
Somehow this tends to derail in the scene making
:light non-responsive.
I will now try it with b52 and X-quartz 2.7.8
:light gets stuck in a big way in a scene where I have a cue with FX's and I use MIDI to flash, to go to a cue and to open a sub. A lot of MIDI communication happening, not necessarily at the same time (the scene opens with a GO TO CUE 24, then after a minute or so it goes to cue 25 which has a long time in / time out, then after a minute or so later it ends with a GO TO cue 29.In the Qlab of that scene I send simultaneously two midi note on (ch 1 note 1 vel 127 + ch 1 note 2 vel 127) and 20 milliseconds later a simultaneous note on of velocity 0 to both channels. These are lightning flashes and some flashes are at lower than vel 127. They are linked to the flash button though (so I flash at lower than full).
:light non-responsive.I will now try it with b52 and X-quartz 2.7.8
- Wilf
il y a 10 ans 10 mois #11250
par Wilf
b52 seems 'safe' up until now (tried the scene thrice now).
Temps de génération de la page : 0.174 secondes
