4.0.0_b5
il y a 12 ans 3 mois #8316 par sl1200mk2
4.0.0_b5 a été créé par sl1200mk2
4.0.0_b5 is online for every supported systems.
change log will come later.... I'm in hurry....
Les utilisateur(s) suivant ont remercié: ramzi.pal
il y a 12 ans 3 mois #8320 par sl1200mk2
Réponse de sl1200mk2 sur le sujet 4.0.0_b5
so:
* add a new 'Extra Dimmer as Intensity' column to the Device listing of the sho. It's usefull for Device that do not handle Intensity attribute.
* add a merging mechanism to swap registered device model with another one. it'll be usefull when Palette will be coded but the purpose is to be able to switch between device when in tour you do not have the same device as at the creation.
* from the main board you can access to several windows for (few for now) commands
add CONTROL command for Lamp On/Off
add FOCUS command for Pan(Fine)/Tilt(Fine)
add BLADE command
in the FOCUS and Blade windows you can hold CTRL to scroll FINE or scroll BOTH parameters
I think you'll need to to rebuild your devices template as the one provided because all parameters you want to use must be set
all library have been updated
please discuss about all of that.
Temps de génération de la page : 0.172 secondes
