MIDI Patch 3.0.10
il y a 14 ans 4 semaines #5018 par dFVarela
MIDI Patch 3.0.10 a été créé par dFVarela
Finaly got my Korg nanoKONTROL2! So I've started to make a 'Start' show whit my MIDI setup and a few more stuff. In order to be able to 'merge' the MIDI patch i've saved it!
I've imported the ASCII file that i wanted to use and then loaded the MIDI patch, checked if everything was running, and it was (no surprise till now), saved the show and SHUTDOWN, tommorow is another day.
Boot up the computer, called DLight--> Open Recent, and only the submasters were working. Loaded again my MIDI patch and everything was working, but when looking to the MIDI Command window there was only the submaster patch on the view and the other controls were working.....
So every time I open the show I've got to load the MIDI patch cause everything that is assigned as NOTE does not import but they are in the .xml file!
-DL 3.0.10
-Windows XP Professional SP2
PS: And now something completely diferent, in version 3.0.9 Linux when a new show was opened there was no Shortcuts available.(Ddin't try 3.0.10 in linux yet)
dFVarela
il y a 14 ans 4 semaines #5022 par sl1200mk2
Réponse de sl1200mk2 sur le sujet MIDI Patch 3.0.10
Hi Daniel,
can you please post both midi xml file and DL sho file?
if you're right, it's a major issue....
can you please test something different:
import your asc
save as the sho
shut down
relaunch DL
open the sho file
import midi patch
save your sho
shut down
relaunch DL
open the sho file and see if midi patch is ok.
i suspect ther might be some errors due to asc importation.
il y a 14 ans 3 semaines #5029 par dFVarela
Réponse de dFVarela sur le sujet MIDI Patch 3.0.10
It's only happening whit XP Professional not whit Windows Vista..... :S
When i get back to Lisbon I'll there you more!
Probably it's only a question of updates! :blush:
dFVarela
il y a 14 ans 2 semaines #5055 par xavier12
Réponse de xavier12 sur le sujet MIDI Patch 3.0.10
Hello
Je viens de me rendre compte du même problème, sur mac et sur win7.
Quand je charge un patch midi dans un show seuls les "control change" sont affichés et les "note" ne le sont pas mais fonctionnent quand même.
Rien de bien grave mais il faut le signaler.
Xavier
il y a 13 ans 11 mois #5092 par sl1200mk2
merci de l'avoir signalé.
il y a 13 ans 10 mois #5220 par rodolpheletourmy
Réponse de rodolpheletourmy sur le sujet MIDI Patch 3.0.10
Je rencontre exactement ce même souci de controlleurs midi, sur Linux !
Et aussi malheureusement, un autre bug dont personne ne semble pourtant parler sur le forum... qui m'arrive regulierement de façon totalement imprévisible, et ce, quelque soit la plateforme (...pas testé Mac), l'ordinateur, le controlleur midi, la version (il est la depuis que j'utilise D::Light soit au moins la version 3.0.2), il s'agit de l'inversion, soudaine, du registre de transfert B, après un transfert exécuté (très déstabilisant pendant un show ;-) )... Et aussi, car ça m'a l'air lié, d'une lenteur soudainement anormale, qui peut aller jusqu'au blocage pur et simple, lorsqu'on veut se balader dans la séquence avec les fonctions Step+ et Step-... Mais ça par contre, c'est nouveau. Ça m'a l'air lié car ces deux soucis surviennent généralement en même temps...
À part ça, c'est une des versions de D::Light les plus stables que j'ai pu utiliser. Et vive le master d'inhibition ! ;-)
Perso, il ne le manque plus que 2 ou 4 petits registres indépendants (non enregistrés dans la conduite, indépendants du grand master), et ce logiciel aura tout ce qu'il me faut.
Alors... Merci !!!
Temps de génération de la page : 0.160 secondes
