Channel check -- freeze program
il y a 14 ans 7 mois #4138 par vbs
Channel check -- freeze program a été créé par vbs
With 3.07 runiing on Osx i have à problem with THE channel check .
When i click channel to check it keeps on runnend Unitill THE last channel..and don,t stop anymore
THE program is stuc and i have to shut down..
regards Vincent
il y a 14 ans 7 mois #4141 par sl1200mk2
Réponse de sl1200mk2 sur le sujet Re: Channel check -- freeze program
Vincent,
in other words you're able to check the channels using down/up arrows, but at the end (the last channel), it goes further and you can't close the check channel windows?
is that your problem?
il y a 14 ans 7 mois #4150 par vbs
Réponse de vbs sur le sujet Re: Channel check -- freeze program
Hi Nico,
No that is not. i use the arrow to check and after checking some channels it keeps on running by it self.
can stop any more.
I have to restart the program. I had this problem 5x in a row so i stopt cheching the channels this way.
The next day the problem did't happen ?????
Vincednt
il y a 14 ans 7 mois #4175 par sl1200mk2
Vincent,
i know this error, it's related to key repetition.... and hard to fix....
can you please try with the latest beta available and if you still got this problem, post in the thread related to 3.0.8_b1 like that i won't forget to fix it.
il y a 14 ans 6 mois #4184 par vbs
Hi
I just tried the 3.0.8 version and it seems to work better, aldo it was not a problem all the time.
Ill let you know if it apears again.
Thank You !
Temps de génération de la page : 0.123 secondes
