3.0.6_b5
yep that's a start.a fair start could be just sending the current cue number as general MSC GO <specific cue> that is loaded/xfaded into x1, and in any "slave" program do the "maths" (exact sequence) of what to do.
for example:
s0 q1
s1 q3 ---- X1
s2 q4 ---- X2
s3 q6
let's say q3 in in red register, a Go command in DL can send MSC GO Q4
we can also you the broadcast byte 0x7F. usefull for example when 2 or 3 software/devices are aware of DL midi speechIF we use outgoing DL MSC, then it would be highly advisable (and, once again, industry standard à la ETC Express) to set an incoming and an outgoing MSC device id; if you really choose so, you can set them to the same, but in some scenarios it's vital to have them separate (just to avoid confusion).
this is the limit of my english knowledge... i don't understand -it should only ever react-Unless a _generic_ GO is called (without <specific cue> parameter), it should only ever react IF it has the specific cue that is called, not perform a generic GO.
what i understand is that you think that DL should not respond to MSC GO unless there's a Q number specified.
if so, can you explain me why? (and does Colin is agree with that?)
- flk
sl1200mk2 écrit: yep that's a start.
for example:
s0 q1
s1 q3 ---- X1
s2 q4 ---- X2
s3 q6
agreed.
sl1200mk2 écrit: we can also you the broadcast byte 0x7F. usefull for example when 2 or 3 software/devices are aware of DL midi speech
as an option, yes. I believe, that would simply be 127 in the field (or 0? but I think that might be an actual specific id, 0...)
sl1200mk2 écrit: this is the limit of my english knowledge... i don't understand -it should only ever react-
Misunderstanding, I think - my fault
Here is what I said in examples:
DL receives:
- Case 1: GO. SO, DL performes xfade on whatever is in X2
- Case 2: GO LX 1.2 ; DL _has_ LX 1.2 in its lists. SO, it loads LX 1.2 into X2 and performes xfade
- Case 3: GO LX 2.4 ; DL _has not_ LX 2.4 in its lists. SO, it should not do _anything_. It should _not_ perform a generic GO on whatever is in X2.
I think
0x7F wich is broadcast hexa code is 247 in base 10.sl1200mk2 écrit:
that means we do not associate outgoing message to ingoing ones.
i'll first try to broadcast outgoing message from DL
agreed, i've modified things for the non floating points Q and scenario you've described is the actual oneDL receives:
- samir
flk écrit:
for example:
s0 q1
s1 q3 ---- X1
s2 q4 ---- X2
s3 q6
agreed.
I disagree
I think your 'Script' parameter for a step is the best method. DL should *not* send a generic GO. You have much less control over what you want to happen if you have worry about what the GO will do.
If possible, the new parameter field would offer
1) a drop-down to select 'type' of script (eg MSC, Other Sysex, Telnet, Serial, whatever)
2 If eg MSC is selected, then a seies of Drop-downs to select eg Device ID, Commands, Cue Number, etc. That way, people who are less 'MIDI-savvy don't have to worry tto much about writing Sysex.
(I will try and attach a screenshot from SFX MSC Cue proprties window to show what I mean)
Best wishes,
- samir
sl1200mk2 écrit: @Freddy
sl1200mk2 écrit:
OK - question - what happens in Case 3 if/wnen you use eg Q 2.4 several times in later steps...? :S
Best wishes,
that's incredible how both Qlab and SFX are similar....
happily
:Light is crossplatform and no one can fork it 'Script' is a plan for future. how near, i cannot tell... but i agree that with such function, it's much more cleaner than spreading GO all around the world.I think your 'Script' parameter for a step is the best method. DL should *not* send a generic GO. You have much less control over what you want to happen if you have worry about what the GO will do.
if both of you are ok to wait the 'script' functionnality, i'll pass on the outgoing MSC message for now
colinc écrit:
sl1200mk2 écrit:
the first one will be used.
moreover, it's a capabilitie of:Light to be able to load same cue several times, but it's a bad practice as Q Number is the most use 'sequential way'.
i initialy thought it could change but from what i saw, i was wrong.
- flk
the first one will be used.OK - question - what happens in Case 3 if/wnen you use eg Q 2.4 several times in later steps...? :S
Best wishes,
Well, I would assume that the cue number is unique across the whole list, or is it not?
- as in, even if the same cue number would appear as a later step, it would be the _same_ cue, right?
I mean, you couldn't program two different cues with the same cue number in DL, right?
Yes, happy to pass that on for now
And thus, just really do what you feel like on the "sending" issues.
I thought 7F is 7 times 16 plus 15 (F) = 127 ?
Anyway, really like where this is going...
Freddy
yes, a Q number is uniqueWell, I would assume that the cue number is unique across the whole list, or is it not?
i guess that issue Colin wanted to emerge is when the same cue is loaded several time in the sequence.
in that case, the first step where desired cue appears will be processed
absofuckinglutely, my mistake, i've computed F7.I thought 7F is 7 times 16 plus 15 (F) = 127 ?
in the Download/Alpha section, i've putted a snapshot of what can be 3.0.6 if you all are agree.
@Colin && Freddy
can you please test all the MSC stuff
@Padbol
est-ce que tu peux essayer les trucs Midi du xfade
thank you for your participation,
- graham
Les deux fader (vert et rouge) bougeait en même temps (avec les même valeurs)
Dlight a planté en arrivant en bout de course je crois.
- graham
- graham
Et si je "rattrape" un effet lancé, Dlight perds la tête, les fader ne fonctionne plus de façon cohérente. Le Xfader reste bloqué sur le chiffre a partir duquel j'ai pris la main.
Dlight ne plante pas, par contre
Le bug de la 3.0.6 B5 c'etait : Dlight plante en fait de course quand on reprend un effet en manuel.
Bon courage!
En pièce jointe : Le crash de la 3.0.6 B5
- samir
sl1200mk2 écrit: ok guys,
@Colin && Freddy
@Padbol
Hi Nicolas,
I've installed the 3.0.6 Alpha. Observations:
The STOP and RESUME commands work as they should, ie STOP on a cue with WAIT pauses Wait and does not run TI/TO, and RESUME restarts Wait; further STOP/RESUME command do properly, and STOP/RESUME on TI/TO work as they should;
The GO Q Number(Integer) and Q Number (Decimal) work ok
BUT - In SFX6, a GO with *no* cue number *does not work*
In SFX6, a GO with *no* cue number looks like this:
F0 7F 00 02 01 01 00 00 F7
ie, it insists on putting in the two delimiting 00's (which are used when specifying CUE LIST or CUE PATH), and DL will not accept this - it will only accept F0 7F 00 02 01 01 F7 (I tested with Bome's SendSX). I know DL does not have this, but would you allow the MSC command set for DL to accept these delimiters please. (When using SFX6 with hardware consoles, I sometimes don't put cue numbers into MSC GO commands as consoles can start numbering differently, or not allow point cues)
Otherwise, it's looking good...
Regards,
oups....,
je viens de reposter une version pour MacOS dans Alpha, peux-tu l'essayer?
@Colin
thank you for your hints, i'll check why it behave like that
you'll have to wait a little bit for the windows installer (i think later in the day), i'll let you know
