- Remerciements reçus 1
3.0.5_b6
- samir
il y a 15 ans 7 mois #2145
par samir
Réponse de samir sur le sujet Re: 3.0.5_b6
Hi
When a submaster is set to 'Time', and for example, has a group attached with eg.'up' time 5 sec, 'down' time 3 sec, then if I use my sub shortcut ('numbersign' here, because UK keyboard has no 'ugrave' key) then 'at_level' the sub jumps straight to the level, ie ignores the time - so is no different to being set to 'Flash'. So eg I type '1<numbersign>=' and the sub is immediately at FF. not climbing to FF over 5 secs as I would expect (and vice-versa going down to 00). The timer only works if I use the mouse on the 'Time' button in the submaster panel in the main window
Best regards
Best regards
il y a 15 ans 7 mois #2146
Réponse de sl1200mk2 sur le sujet Re: 3.0.5_b6
i guess this is the proper way!
the ugraveOrWhatever key assigned to a sub is to select the sub.
at_Level is used (as 4 channels) to set a level.
is you want to use the Timing properties of a sub directly from the keyboard, use F1, F2, F3, etc...
- samir
il y a 15 ans 7 mois #2150
par samir
Aahh... ok - thank you for this - I must have missed those shortcuts...!
Now to go go 305b7...
Best regards
sl1200mk2 écrit: i guess this is the proper way!
Best regards
Temps de génération de la page : 0.249 secondes
