Unzipping the DLD Library file
il y a 4 mois 3 semaines #30322 par Tiepsje
Unzipping the DLD Library file a été créé par Tiepsje
Hi!
I'm having difficulties opening the DLD Library (version 0.45028) on my MacBook Air. The downloaded file is a .z file and is not being recognized by any software I use to unzip files. Can anyone tell me how to open and import this file in D::Light? Hopefully it contains a lot more new fixtures I could use :-)
Thanks!
il y a 4 mois 3 semaines #30323 par sl1200mk2
Réponse de sl1200mk2 sur le sujet Unzipping the DLD Library file
Hi,
as long as you follow releases, you don't need to use that file... update lib is included in the software.
there's even more with beta version on Discord....
Which device do you miss ?
il y a 4 mois 3 semaines #30324 par Tiepsje
Réponse de Tiepsje sur le sujet Unzipping the DLD Library file
Hi Nicolas!
Thanks for your quick response! I do a lot of lighting work in different theaters with lots of different fixtures. When the fixture is not in the D::light library I use GDTF to find a matching file (which most of the time works, otherwise I create my own fixture but that costs more time). I just now updated to the latest version of D::Light and was hoping to replenish the library.
So in short: not missing any fixtures at this moment specifically, just trying to enlarge the library :-)
il y a 4 mois 3 semaines #30325 par sl1200mk2
can you please list me usual brand / models that are often used in your country ?
not all of course but most common...
thanks,
Temps de génération de la page : 0.140 secondes
