The devices aren't at home position when I call them on chaser editor
il y a 1 an 7 mois #28206 par Zensible
Hi, After my last updating (I would swear that this doesn't happen before) the devices aren't at home position when I call them on chaser editor. Aldough the shutter open position is fixed at 20, the strobe tag shows a dot (.) and the spot doesn't work, I have to open the shutter every time I want to start editing a chaser. Is that normal? Can I avoid it?
Thanks
il y a 1 an 7 mois #28208 par sl1200mk2
Hi,
this is the best I can do as indeed Chz does not start from Home... they start from where they are.
For the good, you can let . and give control back to séquence.
Forr the bad, you need to write each state of your devices.
Temps de génération de la page : 0.139 secondes
