sync Dlight FX or movements with audio BPM from Ableton or other daw
- NachoL
il y a 2 ans 4 mois #26888
par NachoL
sync Dlight FX or movements with audio BPM from Ableton or other daw a été créé par NachoL
Hola, I wonder if there is a way to synchronize effects or movements with an external BPM
Thank you
Thank you
il y a 2 ans 4 mois #26890
Réponse de sl1200mk2 sur le sujet sync Dlight FX or movements with audio BPM from Ableton or other daw
hola,
not yet but as you launch the subject...
I initially thought calculating BPM by computing time differences between click on a button, I didn't thought about an external daw's BPM...
Is it a MIDI transport?
I'll try to find docs about that.
il y a 2 ans 4 mois #26891
and another question, if the BPM is let's say 350ms per step I think there will be an option in the speedEditor to ask to which times the BPM should be applied, to tilmeIn/timeOut or holdTime.
I think in case of BPM time control delayTimes won't be calculated.
does that sounds reasonable to you?
- NachoL
il y a 2 ans 4 mois #26893
par NachoL
Réponse de NachoL sur le sujet sync Dlight FX or movements with audio BPM from Ableton or other daw
...sounds complicate to me. but I can give it a try. I'll check the speed editor. BPM (Beats per minute) is a music measure, I never calculated the seconds per beat, it's a bar measure 4/4, 3/4 etc.
I don't know if I can explain me well in English. More and more music shows synchro the songs to light changes and effects. I worked on a show with other software (lightkey) That let you link Ableton live with the program and it makes this very easy and friendly. ...I will check better how is this done
For theatre shows I prefer much more Dlight, but I would really like to be able to use this feature.
thank you
thank you
il y a 2 ans 4 mois #26894
I had a discussion with some guys on the Discord about BPM and it's much more clear now.
I still have some stuff to do before writing that part but now that it's clear it's doable
- NachoL
il y a 2 ans 4 mois #26895
par NachoL
Excellent!! thanx a lot
Greetings
Greetings
Temps de génération de la page : 0.159 secondes
