Selected directory is not writable
il y a 3 ans 2 semaines #25614 par polillin
Selected directory is not writable a été créé par polillin
That's the message I get everytime I try to save. Help!
il y a 3 ans 2 semaines #25615 par sl1200mk2
Réponse de sl1200mk2 sur le sujet Selected directory is not writable
Hi,
is it a macOS or a PC?
also which version of DLight do you use?
il y a 3 ans 2 semaines #25616 par polillin
Réponse de polillin sur le sujet Selected directory is not writable
Windows10, 64 bits.
I use the last D::light 4.3.23, but it happened the same with the previous one
il y a 3 ans 2 semaines #25617 par sl1200mk2
it generally means that you 've attempted to savec a sho while Windows was waiting for a reboot after an upgrade.
so you need to clean stuff a little bit...
-Close your DLight
-Open a file explorer
-navigate to C:
-in the upper side of the explorer, Select View > Show > Hidden items.
(you should see ProgramData folder)
-navigate to ProgramData/DLight folder
-send to trash everything that end or start with 'tmp'
-restart your DLight and try a save as.
tell me how it goes.
il y a 3 ans 2 semaines #25620 par polillin
There's nothing that ends or starts with tmp. I've searched even inside all subfolders. Any other suggestion?
il y a 3 ans 2 semaines #25621 par polillin
By the way, i,ve found I have 2 recovery files. I've tried opening them and 'save as', but I get the same directory not writable message.
il y a 3 ans 2 semaines #25622 par sl1200mk2
Can you post a picture of your ProgramData/DLight folder?
il y a 3 ans 2 semaines - il y a 3 ans 2 semaines #25623 par polillin
il y a 3 ans 2 semaines #25624 par sl1200mk2
OK... and did you try to restart your computer?
il y a 3 ans 2 semaines #25625 par polillin
Yes, I have. Several times. Also run CCleaner several times to eliminate any tmp file and clean registers. The same result.
One observation: I have a different folder to keep my .sho files. And if I rightclick on it, it says it is a only read folder, don't know if it has anything to do with it...
il y a 3 ans 2 semaines #25626 par sl1200mk2
And did you tried to saveAs them in other place?
il y a 3 ans 2 semaines #25627 par polillin
Good clue! It lets me save in desk and in downloads folders, not in documents (Isuspect it is because of that 'only read' configuration, I don`t know why it has changed...) I keep trying, i'll inform as soon as I get any news...
Temps de génération de la page : 0.186 secondes
