Fixture Definition Vari-Lite VL1100TS 16bit (27ch)
il y a 6 ans 7 mois - il y a 6 ans 7 mois #19784 par SaFaRi187
Hi all,
For a new show we are experimenting with a moving head who was available at our venue.
Can anyone help me with a fixture definition file for that specific spot?
I've tried already importing the VL1000 file from the download section on the site, but no luck.
Some weird movements and flickering, I assume that one or more parameters are off...
Also, I've didn't had any luck yet in creating it by myself in the editor of D::Light.
I've joined the DMX-chart in this post in the hope that someone has better luck than me! ;-)
I also joined my best shot in creating a definition for the spot.
Any help would be appreciated,
Kind regards,
Bram
il y a 6 ans 7 mois #19785 par sl1200mk2
Réponse de sl1200mk2 sur le sujet Fixture Definition Vari-Lite VL1100TS 16bit (27ch)
Hi,
can you make a .zip of your .dld?
il y a 6 ans 7 mois #19786 par SaFaRi187
Réponse de SaFaRi187 sur le sujet Fixture Definition Vari-Lite VL1100TS 16bit (27ch)
There you go. Thanks already for your help!
il y a 6 ans 7 mois #19787 par sl1200mk2
so,
it's not easy to work with non RGB nor CMY fixture....
Blue/Amber/Magenta are not common parameters... maybe you should set Cyan/Yellow/Magenta for offset 9, 10 and 11
offset 12 is Gobo (not colorWheel), 13 is rotation and 14 is FINE of 13
except that, your personality should work.
what does not work from your tests?
Les utilisateur(s) suivant ont remercié: SaFaRi187
il y a 6 ans 7 mois #19789 par SaFaRi187
Again, you saved my day!
Everything works as it should be now.
Thanks again Nicolas!
Bon weekend.
Bram
Temps de génération de la page : 0.143 secondes
