Anchor mechanism in OSC doesn't seem to work
il y a 7 ans 1 semaine #18965 par sl1200mk2
Réponse de sl1200mk2 sur le sujet Anchor mechanism in OSC doesn't seem to work
So... I've tried on the PC and obviously it does not work.
I'll be able to fix it then.
Thanks for reporting.
il y a 7 ans 1 jour #18981 par sl1200mk2
Hi,
4.1.04_b5 is online and should fix either sub and channel's OSC control.
at least tell me if it works for you.
I've also fix the /pad/enter 1 message but in your example I didn't succed to make the message to behave on focused exit button (aka Ok or Cancel).
so I've used /pad/clear 1 for Cancel and /pad/enter 1 for Ok
thank you for testing,
il y a 7 ans 1 jour #18985 par stebian
Réponse de stebian sur le sujet Anchor mechanism in OSC doesn't seem to work
Hi Nicolas,
reSync does work as expected now. So does /pad/enter 1 in my example! I still use /pad/errorACKNO 1 for Cancel, which works fine for me. I didn't try /pad/clear 1 tonight. Will do tomorrow. But everything seems to be working for me now.
Thanks a lot!!!
stephan
il y a 7 ans 20 heures #18986 par sl1200mk2
cool !!
thank you for the report.
Temps de génération de la page : 0.370 secondes
