Reset a Show: Freeze and Blackout button
- nomatter
il y a 11 ans 8 mois #9175
par nomatter
Reset a Show: Freeze and Blackout button a été créé par nomatter
Hi Nico,
I'm working to create a reset sequence in Qlab (via OSC) in order to be ready to start the show properly.
So, at the moment: Goto 0, Kill Sub (or any value), Grandmaster, Masters of Sub, Scene and Flash to FF and Freeze and Blackout OFF.
To make masters work I had to send 0 then 255 (e.g. "/grandmaster 0" and then "/grandmaster 255"). And that's ok.
My problem is with Freeze and Blackout functions. They only toggle and I couldn't find how to set to 0 for sure.
Is there something I'm missing or there is not a way to set them off?
Thanks,
Carlo.
Thanks,
Carlo.
il y a 11 ans 8 mois #9186
Réponse de sl1200mk2 sur le sujet Reset a Show: Freeze and Blackout button
Hi Carlo,
I'll check that...
I'll check that...
il y a 11 ans 8 mois #9192
so in order to not mess everything, I've added two methods:
/force/blackout 0/1
/force/freeze 0/1
toggle /pad/blackout and /pad/freeze still behave as expected and with this two new methods, you can do want you want (I guess)
please update the wiki according to this change
thanx
/force/blackout 0/1
/force/freeze 0/1
thanx
- nomatter
il y a 11 ans 8 mois #9195
par nomatter
Réponse de nomatter sur le sujet Reset a Show: Freeze and Blackout button
Hallo Nico,
thanks for your work.
Anyway I'm sorry but with b17 it doesn't work. I've tried some text variation but it doesn't react at all.
I've tried also from outside Qlab but it still doesn't answer.
il y a 11 ans 8 mois #9196
I've work on that after the b17...
you'll have to wait for the b18 (witch can land rather soon as I don't have any job for 2 weeks...)
- nomatter
il y a 11 ans 8 mois #9197
par nomatter
Good. (for the b17 and corrections not the lack of job).
Did you understand why the midi controller connected after program launch still doesn't work? It's very strange: values go up but not down and I'm forced to restart Dligth. And it happen only with subs; channels and masters work.
Cheers,
Carlo.
Cheers,
Carlo.
il y a 11 ans 8 mois #9222
Carlo,
changes are available with b18
- nomatter
il y a 11 ans 8 mois #9233
par nomatter
Great,
new Osc commands work.
Wiki page updated. New complete table for 4.0.0_b18: www.nicole-banana.com/wiki/index.php?title=OSC
And Midi Controlled Subs now work too, even after an hot plug.
Very good.
Thanks,
Carlo.
Very good.
Thanks,
Carlo.
il y a 11 ans 8 mois #9235
hey!
thanx for the wiki update!
Temps de génération de la page : 0.208 secondes
