[résolu] Installation dans Tango Studio
- Machin
J'utilise Tango Studio et je voudrais installer DLight...
Après avoir suivi le tuto qui est ici: www.nicole-banana.com/wiki/index.php?tit...stallation_sur_Linux
Je n'arrive pas à lancer le logiciel.
Avec le lanceur, cela me renvoie:
L'exécution du processus fils « /home/xxx/Bureau/Dlight/DLight-64-Linux/DLight.sh » a échoué (Permission non accordée)
Quand je lance Dlight.sh dans un terminal, cela me retourne:
:~$ sh /home/petit/Bureau/Dlight/DLight-64-Linux/DLight.sh
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.15' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libola.so.1)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.15' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libolacommon.so.0)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libolacommon.so.0)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libtcl8.5.so)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.15' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libtcl8.5.so)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libtk8.5.so)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libxml2.so.2)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.15' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libxml2.so.2)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libnettle.so.5)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libartnet.so.1)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.15' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libartnet.so.1)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/liblo.so.7)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libhpdf-2.4.0dev.so)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libusb-1.0.so.0)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libprotobuf.so.7)
/home/petit/Bureau/Dlight/DLight-64-Linux/bin/DLight: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /home/petit/Bureau/Dlight/DLight-64-Linux/bin/libpng16.so.16)
Je comprends qu'il me manque quelque chose concernant Glib 2.14 et 2.15, mais je ne mes trouve pas dans synaptic.
Si quelqu'un saurait m'aider, merci d'avance...!
est-ce que ça ne serait pas juste une histoire de permission ?
il faut que tu rendes le fichier DLight.sh exécutable. tu peux le faire avec un clic-droit dessus, tu cherches un peu il doit avoir un case à cocher "rendre se fichier exécutable" ou alors dans le terminal :
chmod +x /home/petit/Bureau/Dlight/DLight-64-Linux/DLight.sh
- Machin
Alors, j'ai essayé les deux suite à ton post. Le seul changement est que cela ne me retourne plus de message d'erreur.
Mais rien n'a l'air de se lancer...
- Machin
J'ai utilisé Wine pour installer le .exe du coup.
Et ça se lance!
Ne me reste plus qu'a appréhender DLight maintenant!
Merci à vous!
Cyril.
linux et dlight c'est très stable.
si tu lances DLight.sh via le terminal, tu n'a aucun messages ?
as-tu essayé avec la version 32 bits ?
edit :
check ce post :
www.nicole-banana.com/index.php/forum/1-...-debian-6-0-6-64bits
- Machin
Encore faut-il pouvoir l'installer... Rhoo...je rigole!
Pour le lancement via un terminal cela me retourne la même chose que dans mon premier post.
Si j'ai bien compris le lien que tu m'as donné, il faudrait que je recompile les sources de Glibc...
Et sinon, je n'ai pas essayé la version 32 bits. Je vais commencer par ça dans mes tests.
Merci à toi pour ton oeil extérieur!
- Machin
* via le menu, cela ne donne rien
* via un terminal, cela retourne cela:
petit@petit:~$ sh /home/petit/Bureau/Dlight/DLight-32-Linux/DLight.sh
/home/petit/Bureau/Dlight/DLight-32-Linux/bin/DLight: error while loading shared libraries: libusb-1.0.so.0: cannot open shared object file: No such file or directory
Edit: j'ai récupéré les sources de Glibc 2.15...je ne comprend pas/ ne sais pas/ comment les compiler.
J'ai ouvert le fichier install pour suivre les instructions, mais je ne comprend pas. Mon niveau en américain est moyen...
Si quelqu'un peut me faire la traduction, merci d'avance!
si ton OS est en 64 bits, c'est la version idoine de DL qu'il faut que tu utilises.
regarde cette page:
stackoverflow.com/questions/10863613/how...13-to-2-15-on-debian
et essaye d'installer la glibc 2.15
étant donné le faible nombre d'utilisateur de DL sur Linux c'est beaucoup de boulot pour moi de compiler DL pour chaque distro.... du coup je me suis dis que j'allais le produire sur la plus répandue _ ubuntu, qui même si elle est basée sur un debian est maintenant différente en plusieurs points...
- Machin
Et bien après quelques bidouilles, cela fonctionne grâce au lien que tu as fourni!
Pour les bidouilles, voici comment je me suis arrangé avec le tuto:
* je ne suis pas passé par le tty 1 comme indiqué, j'ai juste ouvert un terminal sous Gnome. Ça permet d'avoir accès au tuto en ligne sans avoir à passer son temps à basculer entre les différentes fenêtres.
* les modifications ont été faites avec "su" et non "sudo", pour une histoire de droits (oui, j'ai un peu bourriné...)
* j'ai ajouté les 2 dépôts indiqués et fait tout bien comme il faut.
Maintenant je peux lancer DLight depuis le menu de Debian...en version 64bits.
Encore merci!
Pas besoin de te flageller sur le pourquoi tu ne l'as sorti que pour Ubuntu. Je comprends tout à fait!
En tout cas tu es présent et tu assures! Alors un grand merci pour tout ce boulot!!!!
Edit:
Après quelques essais comme la création d'un FX, son assignation à un sub est enfin la création d'un link entre ce sub et un step, je peux faire ces retours:
* impossible de rentrer des valeurs, de modifier les temps dans le fx, etc. C'est un peu comme si le clavier n'était pas pris en compte. Mais j'ai pu modifer le nom du sub sans problème.
* j'ai créé tout ça dans la version windows, ait enregistré le .sho. Il est bien ouvert par la version Linux de Dlight et corectement lu. Le fx est envoyé correctement...
Vala vala...
