How to chaser 40 channel easly.
il y a 12 ans 3 semaines #8538 par amedeo
How to chaser 40 channel easly. a été créé par amedeo
i would like to know if there is any possibility to chasing 40 channel in easly way ( Step by Step)
I´m using D-Light Version 3.0.18, and i never used it before for kind of special effects.
Please let me know.
greetings from Germany
Amedeo
il y a 12 ans 3 semaines #8539 par sl1200mk2
Réponse de sl1200mk2 sur le sujet How to chaser 40 channel easly.
if you have in mind a kind of 'wizard' function like avab lightboard, there's no such thing in DL.
you have to build each step one by one...
after, shortcuts are available in the FX editor, so once you're glad with each desired channel's levels, simply use 'R' as Record.
that will record an Fx_Cue and load it in the FX sequence.
hope it helps,
il y a 12 ans 3 semaines #8540 par aroom
Réponse de aroom sur le sujet How to chaser 40 channel easly.
Yep.
Go to Display > FX
Then clic on "Create a New FX"
Select it and clic on "Edit FX" : You are now in the FX Editor
Then simply record the Cue you'll need. In @ mode, you can type "C 12 = F", then "R" to record the Cue
The first Cue will be the first step (step 0) and so on. You can edit Cue and Step order by any moment. You can choose the Time In and Time Out.
Then you may have to learn how to load a Fx in a Submaster and how to link it in a Step in your sequence using Mlink.
Check the forum.
ps. it may be a good idea to update your dlight version
il y a 12 ans 3 semaines #8541 par sl1200mk2
also 3.0.23 is better than 3.0.18...
Temps de génération de la page : 0.141 secondes
