No Shortcuts in Linux!?!?
il y a 12 ans 11 mois - il y a 12 ans 11 mois #7000 par dFVarela
No Shortcuts in Linux!?!? a été créé par dFVarela
Hello:
Got an old LapTop and decided to make a small instalation of Linux in order to have a dedicated OS to run DLight, to achieve that i've decided to install a command line Ubuntu, FluxBox window manager and all the other things i needed to make DLight run (libXss,alsa,etc).
After that gave my user the permissions needed to acess USB and MIDI, almost everything worked out of the box (still having some problems with mounting CD & USB PenDrives), but what's really killing me is that when i launch DL with SUDO it all goes well, with the obvious exception that OLA Server doesn't start, but when lauched as a regular user there aren't no Shortcuts and i'm not able to create my own!
Does anyone have a solution? It's for sure a matter of User permission... But which one?
It would be great if anyone could help me!
Thank you all in advance!
Code:
I/O error : Permission denied
dFVarela
Dernière édition: il y a 12 ans 11 mois par dFVarela. Raison: Forgot the error the terminal gives!
il y a 12 ans 11 mois #7002 par sl1200mk2
Réponse de sl1200mk2 sur le sujet No Shortcuts in Linux!?!?
Hi Daniel,
how did you install the libxml2?
does it belongs to USER group? because writing shortcuts (among almost everything) rely on libxml2.
after for the OLA stuff, it would be great if you report more errors in order to improve the mechanism.
il y a 12 ans 11 mois #7004 par dFVarela
Réponse de dFVarela sur le sujet No Shortcuts in Linux!?!?
Hi Nico:
The only package i needed to instal in order to get DL running was libxss1, and alsa to get the midi working and add my user to audio group to access MIDI.
What is the group i should add my user in order to access Libxml? (I'm sure that will solve the problem!)
Regarding OLA, is not a error:
How to start olad
For testing run olad in non-forking, log to stdout, debug level 3:
olad -l 3
olad refuses to run as root.
( www.opendmx.net/index.php/Using_OLA )
As soon i fix the libxml problem, or other i'll be playing around with OLA and if any errors appears i'll tell you!
Thanks!
Daniel Varela
dFVarela
il y a 12 ans 11 mois #7013 par sl1200mk2
Daniel,
does this happen only with shotcuts?
if yes, it's not a libxml2 issue. if it were, you will not be able to have midi binding, neither any kind of cue or whatever.
there's is a tricky bug with shortcut window (that is fixed in the upcomming beta) that prevent to record any shortcut once you hit the 'Tab' button.
also did you do:
sudo apt-get install xorg-devel
il y a 12 ans 11 mois #7014 par dFVarela
Hi Nico:
I can connect MIDI controls but when exiting i got errors and the MIDI commands are lost!
I didn't install xorg-dev but installing it didn't solve the problem!
It must be a user permission problem because running:
Code:
sudo sh ./DLight.sh
Everything works ok, running as my regular user when it starts i get the error:
Code:
36 times.
dFVarela
il y a 12 ans 11 mois #7015 par sl1200mk2
can you try to copy the DL distro on the desktop and try to launch it from there.
example (just to show you the PATH
sh /home/users/daniel/Desktop/DL/DL.sh
il y a 12 ans 11 mois - il y a 12 ans 11 mois #7016 par dFVarela
Hi:
It is the same.... I got DL error :
Shortcut doesn't exist!
And the same 30 I/O error!
Can someone on linux issue this on a terminal and tell me what grops they belong to?
Code:
cat /etc/group | grep yourusername
Thanks!
dFVarela
il y a 12 ans 11 mois #7017 par sl1200mk2
don't u have a user name with some strange char inside?
DL relies on the user HOME variable.
what's the result of :
echo "$HOME"
il y a 12 ans 11 mois #7018 par dFVarela
Hi:
No my user name is:dlight
and the result is:
/home/dlight!
dFVarela
il y a 12 ans 11 mois #7019 par sl1200mk2
and you try to start DL wich is in a directory that belong to /home/dlight, right?
il y a 12 ans 11 mois #7021 par dFVarela
yes, it is in:
/home/dlight/DLight-32-Linux/
dFVarela
il y a 12 ans 11 mois #7022 par sl1200mk2
just for the fun, don't you wanna try:
export PATH=${PATH}:/home/dlight/DLight-32-Linux/bin
and launch DL again.
il y a 12 ans 11 mois #7023 par sl1200mk2
and to answer your cat question, here's mine
Code:
nico@ubuntu:~$ cat /etc/group | grep nico adm:x:4:nico cdrom:x:24:nico sudo:x:27:nico dip:x:30:nico plugdev:x:46:nico lpadmin:x:109:nico nico:x:1000: sambashare:x:124:nico nico@ubuntu:~$
il y a 12 ans 11 mois #7027 par dFVarela
It's the same errors!Your output is very similar to mine, so it seems it is not a question of permission!
dFVarela
il y a 12 ans 11 mois #7029 par sl1200mk2
nope...
at launch DL attempt to create a .DLightWorkingSho folder in the $HOME directory.
so in your case, that mean in /home/daniel/.DlightWorkingSho
if you display hidden files, do you see this folder?
does it have read/write permissions?
Les utilisateur(s) suivant ont remercié: dFVarela
Temps de génération de la page : 0.253 secondes
