No startup under snowleopard
il y a 16 ans 11 mois #519 par Pierred13
No startup under snowleopard a été créé par Pierred13
My Mac runs under snowleopard. The old versions of D::light are fine. The
64B_X6_XQuartz 1.30 however doesn't start. It gets to the question-dialog of running the script and then it just stops. No crash or anything, but no startup either.
I just reinstalled the X11 version from my snowleopard-disk but that didn't help. Is this a known problem. Or better: is this a repairable problem?
Thanks for any help,
Peter
il y a 16 ans 11 mois #520 par sl1200mk2
Réponse de sl1200mk2 sur le sujet Re:No startup under snowleopard
Peter,
The 64B_X6_XQuartz 1.30 however doesn't start
X6 is a little bit to new for me and i did not take enough time to finalize this release for SL.
the problem is not D::light itself but the script to start it (i guess...).
if X5 version works, i suggest you to use them, otherwise, you'll need to wait till the end of november when the next release will be publish.
if you absolutely want to use X6 version, you'll have to hack the file called /your_path_to_DLight/Contents/Resources/Scripts/main.scpt to tell it to run X11 instead of Xquartz.
scarry isn't it?
Temps de génération de la page : 0.140 secondes
