leter??
il y a 13 ans 2 mois #6624 par paucurses
leter?? a été créé par paucurses
The problem is not solved since the keyboard. When I press any key (backspace either as a command from the shortcut) I get the key in question pursued two interogants = t?? ... How to solve it? I hope quick response!
Thank you!
il y a 13 ans 2 mois #6625 par sl1200mk2
Réponse de sl1200mk2 sur le sujet leter??
hi,
it's difficult to understand what you mean...
for example, when you presse the key e, what do you get?
do you get e??
in that case, can you please specify wich keyboard do u have and wich language configuration.
il y a 13 ans 2 mois #6626 par paucurses
Réponse de paucurses sur le sujet leter??
But where I have to change the settings ...?
il y a 13 ans 2 mois #6627 par sl1200mk2
it was a question...
when you type e, do you get e??
il y a 13 ans 2 mois #6628 par paucurses
Exactly as would have to be to work properly? I had always worked ... In the latest version has stopped working. I in previous versions I also now works properly.
il y a 13 ans 2 mois #6629 par paucurses
YES.
il y a 13 ans 2 mois #6630 par sl1200mk2
did you try with the latest beta?
il y a 13 ans 2 mois #6631 par paucurses
I would say no .. I spent .15 of the .16 ... But now old Verison not succeed ...
il y a 13 ans 2 mois #6632 par paucurses
What is the solution?
il y a 13 ans 2 mois #6633 par paucurses
Above version 3.0.11 does not work. Below all right. I use Windows 7!!! HELP PLIS
il y a 13 ans 2 mois #6636 par sl1200mk2
Hi,
i cannot reverse to such a far release...
so sorry but I do *not* have a solution for you.
here it works as expected.
il y a 13 ans 2 mois #6637 par paucurses
What is the difference between hard keyboard version 3.0.11 and 3.0.16? Here is the solution. Explain please
il y a 13 ans 2 mois #6638 par sl1200mk2
I don't know what is different for you (as I told you, it works on every computer I tried).
il y a 13 ans 2 semaines #6773 par paucurses
The problem is now solved!
Temps de génération de la page : 0.203 secondes
