- Remerciements reçus 1
Save a sho file in 3.15 no output!
- vbs
il y a 13 ans 5 mois #6462
par vbs
Save a sho file in 3.15 no output! a été créé par vbs
Hi Nico
I save my sho file in Dlight 3.15 and open this file it in 3.14 there is no output from the recorded channels
Regards Vincent
Regards Vincent
- vbs
il y a 13 ans 5 mois #6463
par vbs
Réponse de vbs sur le sujet Save a sho file in 3.15 no output!
This is the sho file
il y a 13 ans 4 mois #6470
Réponse de sl1200mk2 sur le sujet Save a sho file in 3.15 no output!
that's something I didn't thought before but as i've changed for 3.0.15 the way that cue's file are recorded (inside the xml file I've changed universe word for ROOM), they cannot be open anymore in pre 3.0.15 release.
3.0.15 can read pre release and release files.
< 3.0.15 can only read < 3.0.15 files.
is it a problem for you?
Nico
Nico
- vbs
il y a 13 ans 4 mois #6473
par vbs
Hi Nico,
It is not a big problem i was just wondering why, this explain the problem.
If i really want to play the sho for some reason in a pre release can i alter the word ROOM?
Regards Vincent
Regards Vincent
il y a 13 ans 4 mois #6476
yes you can, but if you do it manually, it's a boring thing...
I guess a grep command can do that easily for u...
you have to use the .sho Manager to decompress from sho
once you got the whole show directory, in each cue file, you have to change ROOM for universe.
then you'll be able to compress to sho using the .sho manager and re-open your sho with a pre 3.0.15 release
Temps de génération de la page : 0.138 secondes
