OSC fader move
- loesSch
5 years 10 months ago #20833
by loesSch
OSC fader move was created by loesSch
Hi, it's probably been written somewhere in this forum in French already.. sorry but my French is basically not existing.. I am trying to figure out what I can control with OSC in Dlight, so far so good but having issues to control submasters.. doesn't seem to work at all (works fine with midi) .. using the newest DLight and at the moment sending OSC from Qlab (/seq//X2LoadAndFireCue# works fine)
thanks
thanks
5 years 10 months ago #20834
Replied by sl1200mk2 on topic OSC fader move
Hi,
the OSC page is here in the wiki:
getdlight.com/wiki/index.php/OSC#Syntaxe...n_4_.5B2018-02-01.5D
according to this page, the OSC message are:
/sub/x/level [0 to 255]
so for sub 1 at FF, you need to send:
sub/1/level 255
does that works for you?
sub/1/level 255
The following user(s) said Thank You: loesSch
- loesSch
5 years 10 months ago - 5 years 10 months ago #20835
by loesSch
Replied by loesSch on topic OSC fader move
That's exactly what I tried (and all versions similar to it)
but it doesn't work.. and if I listen to the OSC (with OSC_data_monitor) then I also get zero info when I move the faders..
Was working already from that list you suggested
Last edit: 5 years 10 months ago by loesSch.
5 years 10 months ago #20836
ok,
may I ask you to test using the 4.1.14_rc2, please ?
(remove the previous one completely from /Applications _ trash it)
is it better?
is it better?
- loesSch
5 years 10 months ago #20837
by loesSch
Perfect - now it works
5 years 10 months ago #20838
cool,
thank you for your tests.
It also means I have to quickly publish 4.1.14....
Time to create page: 0.148 seconds
