Can't connect iphon osc with dlight
7 years 9 months ago #17757 by NachoL
Can't connect iphon osc with dlight was created by NachoL
I'm sorry, i'm quite new in the forum and i don't find a search tab, probably this thread is already commented.
I don't know what i do wrong, i follow all steps but my iphone doesn´t connect with the Dlight, can somebody help me to see what am I missing?
I have d::light 4.0.24, mac osx 10.13.5 and iphhone with os12.1.2
Thank you
7 years 9 months ago #17758 by aroom
Replied by aroom on topic Can't connect iphon osc with dlight
Hi
Did you check the wiki?
The following user(s) said Thank You: NachoL
7 years 9 months ago #17759 by NachoL
Replied by NachoL on topic Can't connect iphon osc with dlight
Yes, i followed all instructions. I think is something i do wrong about the wifi. I’lll try to put pictures of my steps to see if you can help me. Thank you
7 years 9 months ago #17760 by aroom
That being said the search tab is the last tab on the right. You’ll find some thread about osc who could help you.
7 years 9 months ago #17761 by NachoL
this is what i tried, and i get not connection
...i tried to search the forum but unluckily my french is not enough
Thanx
7 years 9 months ago #17762 by NachoL
This is what i tried in dlight
7 years 9 months ago #17763 by NachoL
sorry, i hope now
7 years 9 months ago #17770 by aroom
I don’t see the IP adress from your Mac. Make sure you setup the right adress in both your phone and dlight
Just setup one up adress in dlight, the one from your smartphone
Don’t use osc bridge if your not using it. Turn it off.
Really re check the wiki. You can translate to in Spanish with google translate.
7 years 9 months ago #17773 by NachoL
Got it!!! Merci encore
7 years 9 months ago #17774 by sl1200mk2
Replied by sl1200mk2 on topic Can't connect iphon osc with dlight
Hi,
Can you please explain what was wrong, or how do you sorted out?
7 years 9 months ago #17775 by NachoL
Replied by NachoL on topic Can't connect iphone osc with dlight
I disabled touch bridge, set the adress port in DLight to match wifi IP from the wifi page in iphone settings (not the IP that appears in touch osc, wich is a different number and confused me) now works fine
7 years 9 months ago #17779 by sl1200mk2
thank you for the explanations
Time to create page: 0.151 seconds
