Touch OSC with Pure data and DLight
15 years 1 month ago #3065 by samir
Replied by samir on topic Re: Touch OSC with Pure data and DLight
sl1200mk2 wrote: can you check what value are sent with push & toggle button?
i can make a check in DL that do not respond to 0 value.
for example if push (or toggle) send
/seq/go 1 when press and /seq/go 0 when release, i can filter the 0.
In the TouchOSC editor, you can see that the 'Value Range', in the template file for DLight-pad_1.8.touchosc, has been set : From: 0 ; To: 1
A quick test, transmitting to a simple test patch in PureData, shows indeed that a button press sends '1' and then release returns to '0'.
But also I noticed that using TouchOSC on the iPod, that using the X1/X2 sliders (on the second page)to change the state of the registers can cause the GO button to run correctly! I can't figure out a pattern yet, but it seems connected...
Regards,
The following user(s) said Thank You: Kassa@Dena
15 years 1 month ago #3066 by samir
Also I notice it does not matter *what* the values in the From and To Range are - I have put both values the same eg : From 0 To 0 ; minus values From -1 to -1 ; and so on
regards
Time to create page: 0.408 seconds
