Virtualisation in Windows11
3 years 8 months ago - 4 months 3 weeks ago #24480
Virtualisation in Windows11 was created by sl1200mk2
Windows 11 have a new policy regarding security... without entering in details it means that Microsoft ships its new system as a 'Virtual System' (more or less exact but many users can understand).
:Light does not run on virtual system (as for 2023/02)...
So if
:light report your computer is running on a virtual system you need to disable it.
In order to do so there's several methods:
-First, you can try to disable Hyper-V mechanism as explained in attached document.
right after, you can try to activate/deactivate your licence.
If things goes well, you're good otherwise you'll need to tweak more...
-Second, you'll need to disable VBS (on Intel computer).
Thanks to @achille.dub here's a link that explain how to do so:
www.netcost-security.fr/guides/guides-te...er-les-performances/
it's in French but easily translatable (or find a source about the same topic in your language)
Hope this helps...
ps: Microsoft provides instructions to enable virtualisation:
support.microsoft.com/en-us/windows/enab...4b-a449-8ced115f58e1
You can follow them as well BUT you'll want to disable virtualisation
here's a link for Asus :
www.asus.com/fr/support/faq/1043992/
:Light does not run on virtual system (as for 2023/02)...So if
:light report your computer is running on a virtual system you need to disable it.In order to do so there's several methods:
Hope this helps...
Last edit: 4 months 3 weeks ago by sl1200mk2.
The following user(s) said Thank You: Spoonspoiler
3 years 4 months ago #25183
Replied by sl1200mk2 on topic Virtualisation in Windows11
une autre explication en Français:
- jbfer0201
9 months 2 days ago #29691
by jbfer0201
jbf
Replied by jbfer0201 on topic Virtualisation in Windows11
Bonjour Nicolas,
J'ai un acer windows 11 processeur amd ryzen 7 260 w/ radeon 780 m Graphics.
Après avoir exploré les différentes manipulations, mis à jour le bios avec le vendeur, je suis face à un problème la virtualisation ne peut pas être enlevée dans le bios ( pas affichée dans les actions possibles).
J'ai décoché tous les fonctions hyper v etc, la virtualisation est toujours en route....
Auriez-vous une idée?
Merci par avance.
jb
Merci par avance.
jb
jbf
9 months 2 days ago #29692
aucune malheureusement... si tu as acheté une licence je peux te la rembourser...
(écris moi en perso si c'est le cas)
mais pour l'instant je n'ai vu qu'un seul ordi comme ça.... qui est listé ici:
getdlight.com/forum/hardware-all/8272-co...not-work-with-dlight
as-tu essayé la méthode isolation du noyau / intégrité de la mémoire comme indiqué ici:
- jbfer0201
9 months 2 days ago #29693
by jbfer0201
jbf
This message contains secure information
jbf
- Otchakbb81
3 months 3 weeks ago #30466
by Otchakbb81
Replied by Otchakbb81 on topic Virtualisation in Windows11 Ordi DELL Plus 16620
Bonjour
Je possède un PC DELL Plus 16620 et j'ai déjà essayé beaucoup de choses. Faut-il déjà activer ou désactiver la virtualisation, je suis un peu perdu. Merci
3 months 3 weeks ago - 3 months 3 weeks ago #30467
Last edit: 3 months 3 weeks ago by sl1200mk2.
Time to create page: 0.777 seconds
