Enttec DMXUSB PRO
- aboll
I suspect a pc use...
Did you install WINUSB driver thanks to zadig.exe on your pc?
- aboll
The code is the same for mk2 and for usbdmxpro.
So it should work out of the box (tested today with several osx systems ).
- aboll
so you have MacOS 10.10.5
when you launch DL and try to connect to the USB DMX widget, it should ask you for a password (this is required to unload ftdi drivers _ on MacOSX, DL does not require any driver).
does this happen?
- aboll
after one hour:
I installed DL (copied from my notebook) in a MacMini and it worked normally.
Also i did installed again at my notebook and the problem persists.
It's a big mystery. I'm sure is not a hardware problem because i tried with two USB DMX from Enttec and both are working.
First i thought if was an USB output problem from my notebook, but also not otherwise when i run LXConsole the DMX device responded normally.
So i rememberedwhat different i did on my computer after last time i did run a show from it.
I downloaded and opened the Korg Kontrol Editor to setup the buttons of my nano control. May this action did affect the USB outputs...?
Notebook... pc are notebook. Mac are macbook, macbook pro...
But previously you said you cannot connect to the usbdmxpro, and now you say that led are blinking.
If they blink it means that the usbdmxpro is well connected and you reach the end of the trial period.
Isn't it the case?
- jgastonraoul
- Thank you received: 4
Which version of
:Light do you use ?Regards,
Jérémie
- aboll
Oh no! Trial period end... yes probably.
But i didn't receive any message.
There is a link to extend period or pay for using DL?
At the donation field?
Thanks.
- aboll
Thanks
Regards.
- got
- Thank you received: 44
You could find an extension here :
getdlight.com/
G68F-UZG5-K4BY-9NJW-XD26-NW2R-46XT (trial extension)
The last release it's the 4.0.1
tell us if it's good
see you
thank you got!!
the trial extension only works with DL 4.0.1
- aboll
Best.
