enttec dmx usb pro pc windows 7
- Rose4Side
10 years 3 months ago #12762
by Rose4Side
enttec dmx usb pro pc windows 7 was created by Rose4Side
i would like to use d::light on my computer, windows 7.
i installed the program, connected the enttec dmxusb pro converter,downloaded drivers from the enttec side and now i'm stuck. my pc recognizes the dmxusb pro but on d::light on "display" - "setup" - "dmx" i can't switch on the dmx. i tried to download libusbx but without success.
can sombody help me with a step by step instruction? is d::light really suitable for pc?
i also understand french, i just can't write or speak it...
thanks a lot,
rose
thanks a lot,
rose
10 years 3 months ago #12763
Replied by sl1200mk2 on topic enttec dmx usb pro pc windows 7
- Rose4Side
10 years 3 months ago #12813
by Rose4Side
Replied by Rose4Side on topic enttec dmx usb pro pc windows 7
thank you for your reply.
already before i found this page and tried to follow the steps. in the end i downloaded another light program, open light, and with this program the conversation between pc, usb dmx converter and dimmer worked.
so i don't know where the problem could be.
i want to make it run because i already know a bit dlight working on the mac of a friend...
thank you for other ideas
10 years 3 months ago #12814
Hi Rose,
I choose this option because it allow me to use the same code on each platform (Mac, PC && LInux).
a quick step by step instructions would be:
-download zadig.exe
-plug the usbPro
-launch zadig.exe
-in the option menu of zadig choose 'list all devices'
-the usbPro should appear
-zadig let you install several kind of driver for the widget, and be sure to choose WINUSB
-click on replace driver
-zadig tells you when installation is complete
-open
:Light
-create a new sho (File/new)
-in the setup of DL, scroll down to DMX part
-choose usbDMX
-click on the ON/OFF led
at this point DL should be connected to the widget
please tell me where it goes wrong
-download zadig.exe
-plug the usbPro
-launch zadig.exe
-open
:Light-create a new sho (File/new)
-choose usbDMX
- Rose4Side
10 years 3 months ago #12815
by Rose4Side
that is what i did, but i will re-try.
unfortunately i don't have the usbdmx pro with me right now, but i will try later and then let you know.
thank you for your fast reply.
rose
rose
10 years 3 months ago #12816
you're welcome
indeed, you need the usbPro to be plugged at some point in order to let zadig install the proper driver.
- Rose4Side
10 years 3 months ago #12837
by Rose4Side
now it works! thank you
Time to create page: 0.142 seconds
