Serial Communication Enttec
13 years 7 months ago #5705 by p.leijstra
Serial Communication Enttec was created by p.leijstra
Hi,
I have a simple question, and also hope there is a simple answer. But maybe someone can help me with some simple knowledge:
How does D::light communicate with the Enttec? I know it's serial communication via the libusbx driver, but what kind of data is send? Is it just an bytearray with DMX values?
Hope someone can clear this up.
Thanks in advance.
Piet
13 years 7 months ago #5713 by sl1200mk2
Replied by sl1200mk2 on topic Serial Communication Enttec
Hi Piet,
exactly, at the end of Sub/channel/curve/grandMaster/everything merge, I fill an unsigned char arry with dmx values I want to send to the usbPro (or everything that is usb/dmx).
the array is prepended with start code, label and some length info, and at the end, the End code is appended
hope this helps,
13 years 7 months ago #5718 by p.leijstra
Replied by p.leijstra on topic Serial Communication Enttec
Hi,
Yess this really helps! Could you explain more about the start/end code and the label? is start and end that hex e7 used in the Enttec document? What label number do you use to send dmx values?
thanks allot!
13 years 7 months ago #5724 by sl1200mk2
start is 0x7E
end is 0xE7
label for sending is 6 (SET_DMX_TX_MODE)
13 years 7 months ago #5725 by p.leijstra
HI, Thnx allot! I used a serial monitor to what a packet looks like (from d::light to enttec) this is wat i get:
7E 06 01 02 00 66 00 00 00 00 00 00 00 00 00 00 00 FE 7F
00 00 7F FE 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 E7
The 7e and e7 are the start and end, the 06 is the label. Are the 01 and 02 the length info?
So if I would like to send commands from flash to the dongle, this is what i have to send right?
Your a really great help!
Thnx,
Piet
The following user(s) said Thank You: colinc
13 years 7 months ago #5728 by sl1200mk2
that's right!
Time to create page: 0.203 seconds
