Arhtnet don't concect windows Xp
11 years 11 months ago #8821 by vbs
I am trying to connect a Entec node to Dlight runing windows Xp.
It is recovering the node but if i start the server it shows waiting for 3 seconds but nothing happens.
Any idee??
Regards Vincent
11 years 11 months ago #8826 by aroom
Replied by aroom on topic Arhtnet don't concect windows Xp
check the ip adress of your node. you may have to switch the "BroadCast ArtPoll" from 255.255.255.255 to 10.255.255.255 or 2.255.255.255
check you firewall
check that both ip adresse from the node and from the computer are different
11 years 11 months ago #8833 by sl1200mk2
Replied by sl1200mk2 on topic Arhtnet don't concect windows Xp
Hi,
that's true but keep in mind that both computer and node address must be on the same IP range.
for example:
computer: 10.0.0.50 (submask 255.0.0.0)
node: 10.0.0.51 (submask 255.0.0.0)
computer: 192.168.1.50 (submask 255.255.255.0)
node: 192.143.200.20 (submask 255.255.255.0)
(this one is not defined by artNet draft that specify 10.x.x.x/2.x.x.x IP range, but it works)
also don't forget to select 'available' at node level before starting the artNet server.
11 years 11 months ago #8841 by vbs
Replied by vbs on topic Arhtnet don't concect windows Xp
Hi
Thanks for your reply.
Putting the ip adres in the Same range works, thanks
Recards Vincent
Time to create page: 0.135 seconds
