ArtNet node from Electron Design (4 DMX universes)
13 years 7 months ago #5732 by noelvd
Does any have experience with this Artnet node ? ( www.electron-design.ru/artnet6_00/an6_00.pdf ).
According to the manual, it should be able to work with up to 6 universes.
I have bought one on ebay (approx.100 Euro) and connected to D::Light. The first tests are promissing :)
When I have more time, I will test a full set, including 2 moving heads (13 channels) and a VaryTec Prestige-II (256 channels).
I'll keep you posted. :P
13 years 7 months ago #5737 by sl1200mk2
keep in mind that DL can only output 4 DMX universes.
moreover, there's something wrong in DL about DMX universes and channel that I plan to change for the 3.0.12
for now, there's a bond between DMX universes and channel numbers and it shouldn't be like that.
Nico
13 years 7 months ago #5739 by noelvd
Don't worry, Nico ;) For the moment, I have more than enough with 1 universe.
But given the low cost of this interface, and the potential to use (with DL) up to 4 universes (2048 channels !), made me decide to give this a try.
That was a risk, of course, given that neither DL not Electron Design could confirm that this would work. But it DOES work (at least, the limit test - 1 universe, and only a handfull of channels- worked flawless).
Best regards,
Noël
Time to create page: 0.211 seconds
