Message Show Control
  • flk
15 years 4 months ago #2711 by flk
Replied by flk on topic Re: Message Show Control
Oh, and PS: Just for the ouside world, when you announce it to avoid confusion, it's "MIDI Show Control" (not message show control) :).
à plus,
Freddy
15 years 4 months ago #2714 by samir
Replied by samir on topic Re: Message Show Control
Hi
I have followed this thread with great interest. When I started experimenting with DLight, I was interested to see if SFX6 ( from Stage Research - Windows equivalent to QLab) would 'talk to' DLight via LoopBe, so I loaded an MSC 'GO' (no cue number) command in SFX, and then copied and pasted the Sysex from the GO into the DLight MIDI command window, with DLight's GO command as its target. It works perfectly, and interestingly, in the Command/MIDICommand list in DLight, the MSC GO sysex is listed as 'PLAY'.
15 years 4 months ago #2718 by sl1200mk2
Replied by sl1200mk2 on topic Re: Message Show Control
@colin,
can you try with the 3.0.6_b5 release the MSC stuff on windows and report any wrong (or right) behaviour?
also you're trick is very fair ;-)
15 years 4 months ago #2721 by samir
Hi Nicolas,
Yes - I have 3.0.6_b5 on - I have posted some initial queries on the 3.0.6_b5 Release thread on the Releases Forum. I will keep testing...
Regards,
12 years 6 months ago #7913 by fIfOU
Replied by fIfOU on topic Re: Message Show Control
Salut tous,
Je sais ce post est vieux mais je viens de découvrir les possibilités du Midi Show Control.
J'aimerais m'en servir avec QLab mais dans l'autre sens que celui décrit dans ce post:
Tout gérer depuis D::Light, avec Qlab qui envoie des cues son. QLab devant rester synchro au niveau des n° de steps même si dans D::Light on fait des step+ step- et surtout n'avoir à créer dans QLab que les n° de steps où il y a du son...
Après plusieurs tests, il me semble que D::Light ne sait que recevoir du Midi Show Control mais pas en émettre.. Right ?
Pour l'instant j'arrive à synchroniser les deux softs en faisant une passerelle avec Isadora (encore !?), cela donne :
D::Light OSC => Isadora => QLab MidiShow Control
Je me demande juste, si il n'y a pas plus simple.
Philippe
12 years 6 months ago #7914 by colinc
Replied by colinc on topic Re: Message Show Control
fIfOU wrote: Salut tous,
Philippe
Right
Time to create page: 0.559 seconds
