- Thank you received: 3
Device editing / ETC S4 LED
- Wilf
The personality files, when I open them again, are all mixed up...? They're not how I made them. Are they editable in a text editor?
this is what I told you... b54 can mix attribut in a strange way if you remove some attribut.
- Wilf
you SHOULD set the mode version of your personality in the model field of the personality... otherwise they'll all look the same in the 'device listing'
- Wilf
b55 will be better...
I've also added Ctrl+c Ctrl+v to the personality editor as it's quicker to copy/paste instead of typing....
- Wilf
I hope these device personalities are better:
I have to admit that I got a bit lazy at Expolite TR16 on channel 11 and 13 which have a lot of macro / auto functions :whistle:
- Wilf
I don't know it's in the show, this is the one (but I've had the same problems with other shows):
if you clone from a device with no ch assigned, it leads to wrong behavior
- Wilf
here on 10.9 with b55, it clones well
you'll tell me when b55 will be published...
- Wilf
Error: cell index "-1,invPAN" out of range
So it seems 'inverse pan' gives some kind of stack overflow or out of bounds error...?
Edit: When I select 'inverse pan' and don't select 'inverse tilt' I get the same error but then 'invTILT'. When selecting both ticker boxes no cloning will occur but no error will occur too.
Edit 2: Hmmmm... It does crash even when both ticker boxes are selected and I clone after all...
Edit 3: If I don't clone but insert a device on channel 1 and then insert another device and give it channel 2 version 54b crashes immediately too.
Videos are uploading now, I'll edit them in this reply later.
would you mind testing it?
- Wilf
